Fellow 3D-printing enthusiasts i am in a severe pickle,
I have a Cr10s and installed a BlTouch but the issue right now is:
When the Z-Endstop cable(White and Black cable) of the Bltouch is connected to the motherboard, when turning the printer on , the screen is blank/black and no light is coming off the Bltouch sensor which it did when only the 3 wire cable was connected.
When i start the Cr10s with the Z-Endstop cable for the BlTouch disconnected, the Cr10s display works perfectly and shows the menu as usual.
So what is causing the display to not turn on when the White&Black cable of the Bltouch is connected to the Z-endstop port of my Mainboard
The version of TH3D i have installed is Marlin U1.R2.4b
I bought a genuine BlTouch device.
When the Z-endstop cable(Black and white cable ) was disconnected and instead the stock Z-endstop of the Cr10s was connected the Bltouch had a blue light being on but it didn't work at all either.
Meaning using the BlTouch Selftest, Stow and so on options didn't do anything.
Also i had a huge issue with the Cr10s after updating to thew new TH3D Firmware(With the Bltouch option active during compiling) that when i used the move axis function under control, and turned the knob accidentally too much instead of stopping at Z-axis height 0 it goes into -10 for example and the damn nozzle presses itself with force into the glass bed which is really really gutting to see and hear, why does it do this ? Why doesn't the Z-axis move feature not stop at 0, and why does the damn Z-stop that was connected properly not engage even though i can perfectly hear the click and during auto home it engages as well ? How do i disable the function in TH3D firmware for my Cr10s to go beyond 0 (meaning into the negatives ) when moving the Z-axis ?
Please help me.
Please, please, please help me, i beg you, please help me with this.
I'm am very desperate right now.
Creality Cr10s - BlTouch makes my printer not turn on ! Please help !
Re: Creality Cr10s - BlTouch makes my printer not turn on ! Please help !
You might toss this question out to the TH3D support group on Facebook. I'm not sure where to start with those listed issues
It appears that the Bl-Touch is wired incorrectly for your CR 10.
Brown wire is ground, Red wire is power.
Look Here for More information
Connector Pin exchange
I wonder about the TH3D firmware tho...since they obvious sell a competing product....not that they would disable BL Touch or the like...but there may be some additional steps required.
I do not know! I found the Creality CR 10 Wiring diagram for BL-Touch was keeping it for myself if I decided to add BL-Touch.
When I saw this post thought it couldn't hurt so posted just in case it would be helpful in this case.
