Extruder wont extrude Hitop 3DP12
brianmix
3D Printer(s): Hictop 3DP12
Re: Extruder wont extrude Hitop 3DP12
Post by brianmix » January 2nd, 2019, 9:57 pm
Yep your correct. Great eyes you have. Nozel was jammed with plastic I think the Teflon tube was installed upside down.
I have a new heater but it wont heat. Had to wire up to my connector. Are the extruder heater or temp sensor polarized. + or - I see no markings?
Post by Roberts_Clif » January 3rd, 2019, 7:16 am
No!
The Heater is a simple 40 watt wire wound power resistor load/heater.
The Thermister is a simple resistor whose resistance is reduced by heating.
brianmix
Post by brianmix » January 4th, 2019, 11:03 pm
Success. Finally after 3 new stepper motors and 2 new heaters a "good" part!
brianmix
Post by brianmix » January 4th, 2019, 11:33 pm
Spoke too soon. on my third part another heater died. It has 24V going to it, just cold. Is this normal?
Post by GrueMaster » January 5th, 2019, 3:06 am
Are you buying 24V rated heaters? That could explain why you are burning through so many.
Post by Roberts_Clif » January 5th, 2019, 7:56 am
Measure the resistance of one of the heaters.
12volt heater
40wt / 12v = 3.333amps : 12v / 3.33amps = 3.6ohms
24volt heater
40wt / 24v = 1.667amps : 24v / 1.667amps = 14.4ohms
A 12 volt heater will have about 3.6 ohms
A 24 volt heater will have about 14.4 ohms
Resistances will vary with manufactures as I have seen many 40 watts heaters delivering only 38 watts.
The reason is some manufactures trying to save money use a standard 15 ohm heater which will deliver only 38.4 watts.
I have purchased many 12V heaters and received 24 volt heaters and vice versa, it could be merely sellers sending wrong parts.
I now check every part I purchase and label them, as to nozzle heaters the actual resistance is written then they at placed in stock.
The resistances I have logged suggests the Heaters I have purchased are made with Resistors in the 5% Tolerance range.
Return to “General Questions”
