VHS Tape Repair Frame
Show us your latest print!
Post by Roberts_Clif » December 8th, 2018, 9:08 pm
Not sure how many are still using VHS Tape Players, since I repair, clean and do transfers of Video from VHS to Digital data.
Making CD, DVD and Blu-Ray backups of the older Media I have a need for a VHS Tape Frame.
So I have Made this frame and putting it up for anyone who whats to download.
This Skeleton frame of a VHS tape that will allow you to make adjustments to your VHS player/Recorder without the VHS tape getting in the way.
It is designed so it can only be inserted into the Player/Recorder only one direction.
Front is As Shown in the Image below, the notch in the center bottom is a key to allow this side in only.
This should be printed in clear to make it as translucent as possible.
Being translucent the inferred emitters will shine thru so a Dark Black Dot is taped to front of both sides as shown in the following image.
This will defeat the Broke Tape Sensors. .
Attached STL file is for anyone who wants or can use a VHS Tape Frame for VHS tape Player / Recorder cleaning or repair.
VHS Tape Gig.stl
(35.14 KiB) Downloaded 28 times
Re: VHS Tape Repair Frame
Post by LePaul » December 9th, 2018, 10:40 pm
Ironically....
...I found a box of old VHS tapes. Many still sealed. They were Wide Screen versions of movies I had...and tucked away for the day I had a wide screen TV to play them on. Since I have yet to see an HDMI level VCR, I think if I did open them up, the resolution offered would be disappointing
Post by Roberts_Clif » December 10th, 2018, 12:34 pm
There are many VCR's w/HDMI 1080p HD Upconversion thou don't waste your money you will never get a HD video quality from a VHS tape.
As they have to convert the signal using a HD Upconversion circuit like This
Buy New in DVD, Blu-ray or do as I, be nostalgic watch on your HD 1080p TV via the RCA inputs not perfect but nostalgic.
Post by GrueMaster » December 11th, 2018, 9:44 am
For real nostalgia, try modding an Atari 2600 to work on a 44" LCD 1080p monitor. Really makes the pixels come alive.
Post by Roberts_Clif » December 11th, 2018, 11:19 am
I remember my 1st computer a TRS-80 with 16k memory, same block graphics only B&W graphics.
Hand coding Z-80 Assembly language for a new game.
Need my Frog colored picture back though, He helped me Code through the years...
