Odd first layers never seen before.
Fusion (Max)
3D Printer(s): Monoprice Mini Delta, Cr-10
Post by Fusion (Max) » November 22nd, 2018, 10:20 pm
Hello everyone,
This is the first time I have really had this problem, I recently got a ezabl mini for my cr-10 nice little device I think I got it tuned in perfectly(to a point) for my machine. I just did a larger scaled print around 200 mm x 200 mm and one corner about 15 millimeters in the filament raises up for 20 mm and then back to my perfect flush first layer the point where it is, isn't even the starting point of the print so no gloop should be there.
I am really stumped and confused by this so any help would be appreciated :-) Thanks
~Max
Re: Odd first layers never seen before.
Post by LePaul » November 23rd, 2018, 12:34 pm
Which slicer?
In the gcode preview does it show it doing this?
Fusion (Max)
Post by Fusion (Max) » November 25th, 2018, 11:53 am
No not at all its like it just raises up for no apparent reason
Post by Roberts_Clif » November 25th, 2018, 12:41 pm
Did you happen to take a picture of the model you could share with us.
Post by GrueMaster » November 27th, 2018, 9:44 am
Likely a sticking issue. I have this from time to time on my larger prints (CR-10S). I usually end up using a glue stick and covering the area that the print will be. Solves that issue 99.9% of the time.
Post by LePaul » November 29th, 2018, 10:45 am
What's your bed temp?
I'm curious if it's "Elelphant foot"
https://support.3dverkstan.se/article/2 ... ting-guide
Fusion (Max)
Post by Fusion (Max) » December 3rd, 2018, 8:07 am
I am very sorry I have not posted on this thread in a while, but I can't check out the problem anymore cause the cr-10 has since broke. I have a new bowden tube on order but it will be a month or something.
The bed was 60 C
