Page 6 of 6
Re: Cura 2.1 open beta
Posted: June 8th, 2016, 1:48 pm
by Izzy
:-? Does anybody know we're the option to print one at a time or all a once is?
Posted: June 8th, 2016, 2:09 pm
by martin-bienz
Izzy, yes, its in specialmodes and its called print sequence.
Posted: June 8th, 2016, 2:16 pm
by Izzy
Cheers Martin, I wanted to toggle it to see if i could un-stick Cura, no joy :-(
Posted: June 8th, 2016, 2:50 pm
by martin-bienz
Thats sad... can you do me favor, are you on windows? If yes, close cura, go to your local appdata folder (start, run, %localapdata% and enter), rename the cura folder to cura.old or similar. Then start cura again. It should start with default settings. Try again...
Posted: June 8th, 2016, 4:20 pm
by Izzy
Couldn't find the relevant folder, :oops:
I uninstalled Cura and re installed it for a 3rd time, this time it seems to be working :-P
Posted: June 8th, 2016, 6:10 pm
by Izzy
It failed again, but I think it's the virus protector.
I use Pandasoft, it asked permissions etc when installing but then quarantined a file when it ran again, I think I have now allowed the necessary files with permissions.
I will let you know if all ok over the next few days.
Cheers, Izzy
Posted: June 8th, 2016, 9:32 pm
I hadn't thought of that...I run TrendMicro since Symantec was a nightmare for years, hogging up resources
Posted: June 9th, 2016, 3:31 am
by drayson
martin-bienz wrote:Izzy, yes, its in specialmodes and its called print sequence.
thanky for the hint. Tried to test switch from "all at once" to "one at a time" and the strange thing is, the print area height is reduced drastically (blue box)...
Has anybody else seen this?
Posted: June 9th, 2016, 4:30 am
by martin-bienz
drayson wrote: thanky for the hint. Tried to test switch from "all at once" to "one at a time" and the strange thing is, the print area height is reduced drastically (blue box)...
Youp, exactly what happend to me. My "default" is to print one object after the other, so coming from 15.x I changed that setting in 2.x also. If you do that you get that blue box (basically that was there in old cura also, but it just told you something like: "Object is to high, switching to print all at once"). Now that is a pain in the but if you only print one object... right :).
