2.3 beta
nallath
3D Printer(s): Ultimaker
Re: 2.3 beta
Post by nallath »
That's because it created wrong 2.3 profiles ;)
martin-bienz
Re: 2.3 beta
Post by martin-bienz »
nallath wrote:That's because it created wrong 2.3 profiles ;)
hehe...very funny. :-D
Re: 2.3 beta
Is the latest Beta just the same Beta link? I'm assuming you are replacing the Beta with another as you go? That's what I downloaded over the weekend, hoping that's "the latest" :) I'm used to version numbers rising as we go but not sure how you guys handle Beta versions
nallath
Re: 2.3 beta
Post by nallath »
LePaul wrote:Is the latest Beta just the same Beta link? I'm assuming you are replacing the Beta with another as you go? That's what I downloaded over the weekend, hoping that's "the latest" :) I'm used to version numbers rising as we go but not sure how you guys handle Beta versions
Usually the case, but we didn't increase them because of the first one not being built for all platforms. The 2.3.0 you can find on the site is the latest (and might be more recent if you downloaded the first one)
Re: 2.3 beta
It's been almost two weeks...any new changes coming? Fixes?
nallath
Re: 2.3 beta
Post by nallath »
Next release is going to be the "full" release. I think it's planned for ~2 weeks.
Re: 2.3 beta
Okay
I'm not liking the hidden temps, I don't know if you guys are tucking that away to avoid confusion for novices. But (as I posted on Ultimaker) I think it should be visible so I can verify settings. If a print comes off the bed, I can at least SEE what the setting was and adjust it, for example
I don't like these settings being taken away from us. I want to verify things before I launch a 20 hour print!
nallath
Re: 2.3 beta
Post by nallath »
Cura doesn't have the information for the UM2 family. We can't show what we don't have.
Re: 2.3 beta
I don't understand, we had it previously...we could set all the temps. Now they are hidden?
Re: 2.3 beta
Post by Meduza »
If you set Cura to run RepRap style gcode under Machine Settings, then you can change all temperatures, if you run UltiGcode (default on UM2), then you have never been able to set them in Cura, no matter the version.
The UM2 family (wich runs UltiGcode) handles temperatures and material profiles in firmware rather than in the slicer.
Re: 2.3 beta
Okay...that makes a bit more sense.
I'm new to the Ultimaker 2 world :)
Titus
Re: 2.3 beta
Post by Titus »
I wonder, what functions will we see in 2.3 that are new, now that the new UM is being reveiled tomorrow ;)
danilius
Re: 2.3 beta
Post by danilius »
I for one am waiting for the single layer view to return. Desperate for it. I need it for my custom supports.
Titus
Re: 2.3 beta
Post by Titus »
It's there, just a setting somewhere. I believe somewhere on screen on the left. But it's there somewhere!
nallath
Re: 2.3 beta
Post by nallath »
It's there. I sneakily added it. Check your preferences. There should be a "show top layer only" setting there.
