HicTop 3dp-11 installing a BLTouch as a NewBe
Re: HicTop 3dp-11 installing a BLTouch as a NewBe
2 and a half hours later.
After stopping the stepper motors on my Marlin 2.0.9.3 discovered this line need to be enabed
//#define LINEAR_AXES 3
After you should initialize the EEprom
Click Configuration > Click Advanced Settings > Click Initialize EEprom > Click Init
attached are the Configuration.h and Configuration_Adv.h files they work on my Controller.
I re-flashed my Marlin 2.0.9.3 tested again steppers did not turn, Initialized EEprom steppers turn.
It is possible that if you just initialize EEprom it could work.
Configuration_adv.h
(171.76 KiB) Downloaded 759 times
Configuration.h
(108.93 KiB) Downloaded 794 times
bob414
3D Printer(s): Hictop 3dp-11
Post by bob414 »
A newbee mistake, I really have not looked at the -adv_h file. I did a winmerge compare last night. There is a lot that need attention.
I thought the .adv_h was for advanced options, and did not need attention unless using advance systems.
Bob
I have a few important function in configuration_adv.h that I use.
BABYSTEPPING
ADVANCED_PAUSE_FEATURE
PARK_HEAD_ON_PAUSE
I want to use this
POWER_LOSS_RECOVERY
Any new information on your progress
bob414
Post by bob414 »
Just got back in from travel.
Edited the configuration_adv file, and loaded. Still not action when trying to move the axis's.
Here are the files, I edited, compiled and loaded.
Bob
Configuration_adv.h
(171.73 KiB) Downloaded 757 times
Configuration.h
(108.85 KiB) Downloaded 736 times
Downloaded Marlin 2.0.9.3 Installed your configuration.h and Configuration_adv.h complied and uploaded.
Initialized EEProm using LCD test X,Y,Z stepper motors,can-not test extruder unless hot-end is heated to 170C
Connect to terminal Com port 6 on my computer
tested Min End-stop switches
Marlin 2.0.9.3
echo: Last Updated: 2021-09-03 | Author: (HicTop3dp11_Bob)
echo: Compiled: Jan 15 2022
echo: Free Memory: 4814 PlannerBufferBytes: 1456
echo:V86 stored settings retrieved (636 bytes; crc 53479)
Reporting endstop status
x_min: open
y_min: open
z_min: open
ok
x_min: TRIGGERED
y_min: open
z_min: open
ok
x_min: open
y_min: TRIGGERED
z_min: open
ok
x_min: open
y_min: open
z_min: TRIGGERED
ok
echo:; Linear Units:
echo: G21 ; (mm)
echo:; Temperature Units:
echo: M149 C ; Units in Celsius
echo:; Filament settings (Disabled):
echo: M200 S0 D1.75
echo:; Steps per unit:
echo: M92 X80.00 Y80.00 Z2560.00 E94.50
echo:; Max feedrates (units/s):
echo: M203 X300.00 Y300.00 Z5.00 E25.00
echo:; Max Acceleration (units/s2):
echo: M201 X3000.00 Y3000.00 Z100.00 E10000.00
echo:; Acceleration (units/s2) (P<print-accel> R<retract-accel> T<travel-accel>):
echo: M204 P3000.00 R3000.00 T3000.00
echo:; Advanced (B<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> J<junc_dev>):
echo: M205 B20000.00 S0.00 T0.00 J0.01
echo:; Home offset:
echo: M206 X0.00 Y0.00 Z0.00
echo:; Material heatup parameters:
echo: M145 S0 H180.00 B50.00 F0
echo: M145 S1 H240.00 B96.00 F0
echo:; Hotend PID:
echo: M301 P22.20 I1.08 D114.00
echo:; Filament load/unload:
echo: M603 L0.00 U100.00 ; (mm)
ok
I do not see a problem
bob414
Post by bob414 »
recompiled, reinstalled, heated the extruder to 200. Tried moving X,Y,X axis from the LCD panel, nothing.
Thanks for all your help, I will try loading it from CURA, tomorrow. I am running out of ideas, and hair!
Bob
Did you
Click on Configuration
Click on Advanced Settings
Click on Initialize EEprom
Click on Init
The new configuration settings need to be read from firmware.
bob414
Post by bob414 »
Thank you!!! Thank you!!! That did it!
I knew it was something I was missing. Never heard of init EEprom until that post. I now have movement when directing x,y,z,extruder steppers.
I now can test printer and work on getting the Bltouch to work.
I previously posted it in this thread.
This is one of the functions of marlin that I can not express enough.
After flashing on Marlin to clear the old settings you have to read the new firmware settings using.
I am glad we go this part working. When you need more help Post we will be here.
Last edited by Roberts_Clif on January 16th, 2022, 7:22 pm, edited 1 time in total.
Oh Have one more suggestion.
Every time my compiled firmware Worked, I make a backup of the entire directory for Archival purposes " this mean you never change this copy"
If you want to make changes copy this archive to another directory give it a distinctive name, make your changes when it works archive it.
In this way you will always have a backup in case something goes wrong, that you know will work...
I have a folder for every Marlin I have modified with sub-folders of every change made for every user I helped make changes for ect.....
This folder is 6.5GB, I have Backup of this for Archival purposes on four Computers.
You may ask Why!!! Because I wrote a program once that took me 2 years to complete and my hard drive crashed now it is gone.
I decided did not want too ever loose data again, An guess what Murphy struck me again still looking for where the backup is...
bob414
Post by bob414 »
I stated up front, that I was a NewBEE. But, thanks for your patience.
I am a FIRM believer, in backups and saving working copies. I even have all my email backed up, since 1995, each year copied on 2 CD's or DVD's and a thumb drive and newer stuff on the cloud with idrive.
Thanks for the advice, I already have 4 complete directories, for my one working one.
I am finishing installing my BLTouch, and if I can get thru with all these Medical appointments. I might have time to get that working.
Bob
@bob414
You are a smart individual, an you will get this working.
You have already accomplished the hardest of the 3D Printer leaning curve. How to make a broken 3D Printer work again.
An FYI "The cloud is just someone else's computer hard drive !.!.
bob414
Post by bob414 »
I have search the forum and web. I found the MPK V1, but no instructions on where to connect the BLTouch.
The Z- endstop is obvious, but with the 3 wire connector, I have at least 3 or 4 possible places and none are labeled with anything that I can decipher.
Should I just get a new motherboard? If so which ones fit the mounting on the 3DP-11?
Bob
Found some information from a person I helped a long time ago.
My printer uses an MPX .3 board should be compatible with Our MPK V1
#define SERVO0_PIN 11 // D11 Connector.
An follow instructions on ANTCLAB’s page.
Return to “General Questions”
