UMO / UMO+ Firmware
Re: UMO / UMO+ Firmware
You guys do good work!
						- antiklesys
Just added the support for UMO2 Style Z end-stop as per Neotko's mod: https://ultimaker.com/en/community/2212 ... mit-on-umo
This can be enabled in configuration.h by uncommenting //#define UMO_BOTTOM_Z_STOP_MOD
Changes can be found at: https://github.com/Antiklesys/Marlin-1/ ... d3cf5389ba
AND: https://github.com/Antiklesys/Marlin-1/ ... b5c87d591d
					Last edited by antiklesys on January 23rd, 2017, 12:28 pm, edited 1 time in total.
						- antiklesys
I now finished the bed leveling routine!
This adds an extra menu item in the Prepare menu and allows the user to adjust the bed level in 3 points (just like Cura's routine when connecting the machine via USB).
You can find the changes here: https://github.com/Antiklesys/Marlin-1/ ... 561bfcf60b
- antiklesys
What happened to Amedee by the way?
						- antiklesys
Fixed an issue with editing negative values in the display.
Code is here: https://github.com/Antiklesys/Marlin-1/ ... 9a12f4c083
Now it's possible to edit the Z offset from Neotko's mod directly from within the display
- drayson
reg amedee... good question. seems that he wasnt here since end of dec....
