Page 17 of 19
Re: UMO / UMO+ Firmware
Posted: November 22nd, 2016, 3:24 pm
Wow, that's an old post you linked
Posted: November 22nd, 2016, 3:32 pm
by antiklesys
Found the issue, I had to go and change Marlin_main.cpp in the following way:
- for(int8_t i = 0; i < (int8_t)sizeof(sensitive_pins); i++)
+ for(uint8_t i = 0; i < (sizeof(sensitive_pins)/sizeof(sensitive_pins[0])); ++i)
This is a bug fix of:
https://ultimaker.com/en/community/9683 ... ed-pwm-bug
Can we please have this added in this firmware?
Posted: November 23rd, 2016, 1:33 pm
by Amedee
Yep, good catch...
With the overrun you could have any pin blacklisted at random.
(Interesting BTW, that the FAN_PIN is in the blacklist array, while M42 handle the fan case
I'll push that at the earliest opportunity
Posted: November 23rd, 2016, 4:29 pm
by drayson
Great, thanks
Posted: November 29th, 2016, 9:21 am
by antiklesys
Hi Amedee,
Quick question for you specifically: does the marlin branch mentioned in this thread support this?
https://ultimaker.com/en/community/8062 ... -board-fix
Posted: November 29th, 2016, 3:12 pm
by Amedee
Not sure I get the question correctly...
My firmware fork fully support the 'Full Graphic Smart Controller', this is what I have on my UMO.
Posted: December 1st, 2016, 10:31 am
by antiklesys
Thanks man for the confirmation!
Yes I saw your pics and it looks lovely!
Posted: December 2nd, 2016, 5:18 am
by antiklesys
Just a quick question for you still: how did fix it to the UM? Do you have the files for a different holder?
Posted: December 2nd, 2016, 5:41 am
by Amedee
Posted: December 15th, 2016, 5:42 am
by antiklesys
Hey Amedee,
Quick question for you here:
In configuration.h I defined the following:
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
However when compiling with Arduino IDE 1.06 it fails as I get the error:
'u8g_fntpgm_uint8_t' does not name a type
This refers to line:
const u8g_fntpgm_uint8_t u8g_font_6x9[2300] U8G_SECTION(".progmem.u8g_font_6x9") = {
in file: dogm_font_data_marlin.h
Any clues?
Posted: December 15th, 2016, 5:55 am
by Amedee
Did you install the U8g library? (
https://github.com/olikraus/u8glib )
Posted: December 15th, 2016, 6:01 am
by antiklesys
Yes, fixed now. Forgot to restart the ide after a manual installation of the library.
Noob me
Posted: December 16th, 2016, 8:57 am
by antiklesys
Currently trying to implement a bed leveling routine.
So far it failed, not sure if it's the M0 fault or something else.
Your thoughts?
https://github.com/Antiklesys/Marlin-1/ ... fd0ceb6efd
Posted: December 16th, 2016, 5:32 pm
by Amedee
That won't work, you can't enqueue commands like that, the circular buffer is way to small
Posted: December 16th, 2016, 5:58 pm
by Amedee
Since a couple of people started to make bad press around my builder in the UM forum, I decided to log the builds.
I am not looking at personal info, I just file the md5 hash of the build and the parameters. That way if somebody tells me it does not run, with the hash I can find back the parameters that were used for that particular build.
Now in less than a month (27 days to be precise) I have logged 150 builds
Of course it does not mean that all these firmware were actually installed, some people just try some options and leave, but the visibility is definitely higher than what I though...
From the web stats, the biggest 'referrer' is
Neotko's article on the UM forum, and quite some people also follow the links where the builder is mentioned in the various UM forum threads.
Interesting...
