Page 11 of 30
Posted: March 25th, 2016, 8:54 pm
by Anders Olsson
Well, I probably would be a bit careful with the burner regardless of what I use it for.
I did partially deform a heater block once when I was burning it clean of polycarbonate :oops:
Either way though, the burner is one thing that people would come up with using, so it would be good to know if the ruby nozzle is much less likely to survive that treatment than a normal brass nozzle :-)
Posted: March 26th, 2016, 5:57 am
by PeggyB
as a jeweler, there are some stones that can be heated, like diamant, cubic zirconium, garnet. For other stones it depends on the inclusions/irregularities, the heat could influence the color. I guess you are using the artificial rubies... But most important: don't throw it in cold water when hot!
Posted: March 26th, 2016, 6:51 am
by Amedee
Neotko wrote:Won't a burner 800-1500C damage the brass that has a starting melt point of 1000C ?
You don't want to burn that hot -- just enough to burn our the plastic residue...
Just in case, I found back the original Korneel post re. this method. I used it a couple of times and found it very efficient.
Posted: March 26th, 2016, 7:47 am
by ivan.akapulko
Anders, check this out: http://www.tisncm.ru/research-departmen ... s_eng.html
Just one week of work (if i understand correctly), and you can take something much more perfect than ruby :)
Posted: March 26th, 2016, 7:48 am
by ivan.akapulko
OMFG! Gears from diamond monocrystal!
Posted: March 26th, 2016, 10:02 am
by Anders Olsson
ivan.akapulko wrote:Anders, check this out: http://www.tisncm.ru/research-departmen ... s_eng.html
In fact, I know two guys at the University who are operating diamond growth machines :-)
It will be difficult to get diamond orifices down to reasonable price levels though since the process is very slow, drilling holes in diamond is very difficult and high demand from industry tends to set a minimum price for diamond.
We have been discussing this several times at work actually and my conclusion is always ruby will be good enough for what people are likely to print.
It might wear slightly with boron carbide but it is cheap enough to replace then.
That said, we might make a diamond nozzle in the future, partly because it has interesting properties and partly just because we can :-)
It will probably designed a bit differently though if we decide to make it.
Posted: March 28th, 2016, 3:23 pm
by Blizz
@Anders: Might be of interest: Tungsten nozzle :)
Posted: March 31st, 2016, 2:12 pm
Yesterday installed back the Ruby nozzle and printed some
E3D nozzle
Ruby
But I had to uninstall it, since my alu umo+ block screw died (aluminium suuuuucks) and after trying to fix it now the pt100 it's totally dead (was in bad shape already). So now I'm waiting to assemble a um2 hotend and forget about this umo+ hotend on one machine at least.
The number of thinks that have died on my main umo+ look just like a 'built-in obsolescence' just after 1month of warranty off, heater 1 board controller died, now the hotend goes bye bye with the pt100 on the way, oh and also heater (cable) 1 also died... /sulk
Posted: March 31st, 2016, 3:01 pm
Oh sorry to hear that. I haven't touched my printer in a month, so busy with CNC parts
I am trying to see the differences between the two prints, look good on both!
Posted: March 31st, 2016, 3:05 pm
Indeed now that I removed the um2 feeder motor and fixed the error number 21 on my 1.75mm assembly, it prints just like the other with the bonis of overhangs and a much better layer over layer depositions. But ofc to see the difference you need to print the stuff over :D
Yeah been having a bad printer week. Too much spares to buy!
Posted: April 13th, 2016, 4:45 pm
by Anders Olsson
So, things are finally moving again here :-)
I will start collecting addresses shortly of those of you who did not get a ruby nozzle yet.
It has to be mentioned that these are still prototypes, although made in a professional workshop.
I have already made a few changes for the next batch to make assembly easier and make the nozzle more robust.
That does not mean the prototypes are bad in any way, just that you might be slightly more likely to ruin tham then the next batch.
What I would like feedback on for this batch is the fixing of the ruby, potential for leaks and the thermal conductivity (printing at high feed rates).
Posted: April 13th, 2016, 6:33 pm
by Titus
It looks damn sexy!
Posted: April 14th, 2016, 1:18 am
by Blizz
Soooo prrrrreeetty :)
Posted: April 14th, 2016, 2:42 am
by martin-bienz
really cool!
Posted: April 14th, 2016, 10:34 am
by Izzy
It's taken a while for me to reply as I had to but my iPad in its waterproof/drool proof cover. :lol:
