JoelR wrote:Does moving the x-axis via the LCD result in the same movement ( (+) = Left; (-) = Right)? If so, your stepper pins are backwards. Either swap them manually (preferred) or change the setting in Marlin:
#define INVERT_X_DIR true
If it is only occurring in Simplify3d, check your settings and see what GCode is being produced, Make sure it is sending to 0,0,0 and that home is defined as 0,0,0 and not center of the bed. I do not use Slimplify3d so not sure the available settings.
Thanks Joel I will give that a go, to find out what happens. I got a .hex code fomr HICTOP fdor the printer, do you know how to load this into
Adruino.
Ive just checked and moving the x axis + moved left, but cant move right? How do i manually change the stepper pins?
Thanks Stu
