Second prints on Ultimaker 2 require more priming
Post by LePaul » December 6th, 2016, 10:21 am
Hey Nallath,
This might be a firmware question....
I know the retraction after a print is complete is a bit extreme. For a second print, I always wind up going through the UM2's menu's to heat the nozzle, move material, then load the next print.
It would be really neat if there was some means to fix this....I'm just not sure if this should be within Cura or not
Asides the manual approach...any ideas?
nallath
3D Printer(s): Ultimaker
Re: Second prints on Ultimaker 2 require more priming
Post by nallath » December 6th, 2016, 11:13 am
Cura can fix this, but i'm not sure who put the retraction there in the first place. If the firmware does it, i'd say that it's also the firmware's problem of fixing it.
Post by LePaul » December 6th, 2016, 1:06 pm
Can you tell me if that's an issue being worked on? Or maybe add it to the list :)
nallath
Post by nallath » December 8th, 2016, 3:31 am
Not as far as I'm aware. But we have about 800 open issues for Cura alone, so it's getting a bit tricky to keep track of everything.
Post by Izzy » December 8th, 2016, 5:13 am
The only other quick fix I use is to always use the skirt to prime, that way everything settles in during the skirt print and seems fine for the main print.
Izzy.
Post by reibuehl » December 8th, 2016, 5:35 am
Unfortunately that does not seem to work for me. I usually print two lines of skirt and have already doubled the amount of priming but often if not most of the time I need much more until I see the first plastic extruded.
Reiner.
Post by LePaul » December 8th, 2016, 10:09 am
Same, I had skirt set to 3 and it still isn't primed enough for a successful print.
Post by Izzy » December 8th, 2016, 10:58 am
Ok interesting, do you have an i2k fitted, and if so what does the filament end look like on the retraction and can you easyily manually prime or is there a bit of resistance?
It could be that the inner diameter is a bit small and just needs increasing by 0.05mm or so
Izzy.
Post by reibuehl » December 8th, 2016, 11:26 am
I have removed the I2K at the moment. Yes, there is resistance when priming. Sometimes the feeder even starts to skip when I do manual extrude via the move material command to get the flow started.
Reiner.
Post by LePaul » December 8th, 2016, 11:29 am
I've got the 2+ setup, so I just crank away until I get filament moving through, I stop after about 12-15 inches of material has moved along
Post by Izzy » December 8th, 2016, 12:06 pm
That's a lot of priming Paul.
When I had this problems I checked my i2k which was a little snug for some filament tolerances, I think I increased the bore to 3.2mm and this solved my problems.
I seemed that the end of the filament was slightly larger and it took a little hike to become plyable enough to pass through into the nozzle area.
As for Paul, you must have a large amount of filament extruded through the nozzle on that amount of priming.
Izzy.
Post by LePaul » December 8th, 2016, 12:12 pm
Well for the first print, I do not have this issue. It's the darn firmware doing this massive retraction that makes it necessary.
Post by Izzy » December 8th, 2016, 2:11 pm
That is strange, is it modified or straight downloaded
Izzy.
Post by LePaul » December 8th, 2016, 2:22 pm
Izzy wrote:That is strange, is it modified or straight downloaded
Latest firmware for 2+
Post by Izzy » December 8th, 2016, 3:46 pm
Ok in that case I think you need to dial down the bad luck demigod dial a tad :lol:
Izzy.
Return to “Cura”
Users browsing this forum: Google [Bot] and 3 guests
