On the UM3?
LePaul wrote:On the UM3?
Yeah :)
gudo wrote:Hi to all !
@ Neotko
Sweet ! :-P
Thanks men. Without you this um3 would be just a very expensive lightbox XD
LePaul wrote:I'm curious how it performs...same? Better? Worse? than the stock?
My plan is to refurbish completely the machine, so I don't think it will print anything before next year ;-)
But the idea is to use it mainly for materials that the UMO hot end can't print because of the temperature...
nallath
3D Printer(s): Ultimaker
Post by nallath »
Neotko wrote: Fonts quality should be better but S3D has a small bug that doesn't allow me to wipe+retract when using dual.
What? Bugs in s3d? :O (sorry, couldn't help myself)
Other than that, i've been gorging myself upon the unholy candy called "Pepernoten" because of sinterklaas (and the reception has a big jar filled with them, which I pass every time I get up to get coffee...)
Indeed is a bit annoying bug (yeah XD). Basically is a bit stupid and while activating wipe+retract it confuses and 1/5 times uses the retraction distance + toolchange distance. Ofc my feeder can keep up with that but is changes the wipe making visible errors on some spots. So yeah, Cura is MUCH better atm for dual. But disabling that wipe+retract fixes the issue and changing the temps/speed/coasting I can get almost (just almost) close to the same print results.
Oh forgot to add. The bug occurs while doing one yo other process. In theory it should only happen prior a tool change, but nope. Anyhow I think I got a script to solve the issue. Not sure yet
Post by ivan.akapulko »
@Amedee! Happy birthday, dude!
Happy birthday to Amedee, your catching up with us oldies
martin-bienz
Post by martin-bienz »
Happy birthday Amedee! Santa coming to Belgium? :)
Happy birthday @amedee !!!!!
Post by nilrog »
Grattis på födelsedagen @amedee ! :-)
Thanks guys, but it is actually not my birthday :oops: , but the one of the bear :-P
Bommeltje's birthday
Happy Bearthday then!!
Best video ever.
