Spool holder with built-in scale
I was wondering if it would be possible to print a spool holder with a built in load cell that is read by a little controller that shows the weight of the filament that is still left on the spool. Does that sound plausible?
danilius
Re: Spool holder with built-in scale
Interesting.
I just ordered a 3KG load cell and a hx711 load cell amplifier board... I hope it arrives before Christmas so that I can experiment with it
MTVDNA
Take a look here: http://marcuswolschon.blogspot.nl/2016/ ... emote.html
This guy built a filament sensor with a load cell in the spool holder
The load cell and amplifier he used look like they are similar to what I ordered. So I seem to be on the right track
- Titus
Interesting thought! Calibration and stuff will be tough, but once you get that working it should be quite reliable.
I was hoping to get away cheap by using an empty and a full spool and then adjusting the values so that the result matches the one I get from my kitchen scale...
My intension is more to have a rough estimate available to see before a print if it will work or not.
- Titus
Ah I thought you wanted to use it for either pricing or fault detection.
Simple estimate should work yesh
The problem with scales is that they don't measure right if they are not nice & flat. So if you bump against your printer, it will give wrong readings.
If that becomes a problem, I might have to take a bunch of samples and compare them to detect such glitches.
I think the (de)accelerations of the head will also influence the results. They can generate quite a bit of vibrations.
My plans are not so advanced as the ones of the guy that @MTVDNA linked to
As a first step, I would only like see how much is left before I start a print without having to unload the filament and put it on the kitchen scale. Then I can compare it with the filament weight calculation I get from Cura and the printer firmware to have a rough idea if the rest on the spool will be sufficient for that print.
Indeed. Specially with half size smaller bearings...nallath wrote:I think the (de)accelerations of the head will also influence the results. They can generate quite a bit of vibrations.
Anyhow a system like this could work like current tags. You know how much you have before printing (no vibrations) and if weight = length = ok, then you print. At the end of the print thr length used is check vs the weight and updated to the user. You don't need to check constantly how much weights but if you can print the amount asked.
I finally got all the printed and sourced parts together to setup a test. Here is the first prototype:
I calibrated it and now need to refine the code and add a small display
I am a little unsure on what features are really needed - maybe a selectable "empty spool value" that gets automatically deducted from the measured weight...
