The MATERIAL.TXT project
Well, I added nGen to mine (scroll to bottom)
Maybe we can come up with a master file for a variety of filaments?
MATERIAL.TXT
(3.74 KiB) Downloaded 490 times
Code: Select all
[material]
name=PLA
temperature=210
temperature_0.40=210
retraction_length_0.40=6.50
retraction_speed_0.40=25.00
temperature_0.25=195
retraction_length_0.25=6.50
retraction_speed_0.25=25.00
temperature_0.60=230
retraction_length_0.60=6.50
retraction_speed_0.60=25.00
temperature_0.80=240
retraction_length_0.80=6.50
retraction_speed_0.80=25.00
temperature_1.00=240
retraction_length_1.00=6.50
retraction_speed_1.00=25.00
bed_temperature=60
fan_speed=100
flow=100
diameter=2.85
[material]
name=ABS
temperature=260
temperature_0.40=250
temperature_0.25=245
temperature_0.60=260
temperature_0.80=260
temperature_1.00=260
bed_temperature=80
fan_speed=100
flow=107
diameter=2.85
[material]
name=CPE
temperature=250
bed_temperature=70
fan_speed=100
flow=100
diameter=2.85
[material]
name=PC
temperature=260
temperature_0.40=260
temperature_0.25=260
bed_temperature=110
fan_speed=100
flow=100
diameter=2.85
[material]
name=Nylon
temperature=250
temperature_0.25=240
temperature_0.60=255
bed_temperature=60
fan_speed=100
flow=100
diameter=2.85
[material]
name=CPE+
temperature=260
bed_temperature=110
fan_speed=100
flow=100
diameter=2.85
[material]
name=TPU 95A
temperature=235
temperature_0.40=235
retraction_length_0.40=10.00
temperature_0.25=235
retraction_length_0.25=10.00
temperature_0.60=235
retraction_length_0.60=10.00
temperature_0.80=235
retraction_length_0.80=10.00
temperature_1.00=235
retraction_length_1.00=10.00
bed_temperature=70
fan_speed=100
flow=100
diameter=2.85
[material]
name=nGen
temperature=230
temperature_0.40=230
retraction_length_0.40=4.5
retraction_speed_0.40=45.00
bed_temperature=80
fan_speed=50
flow=100
diameter=2.85
Re: The MATERIAL.TXT project
Well I learned a few lessons already...
1) Despite the retraction settings in the MATERIALS.TXT, it seems Cura will completely ignore them. I went to see if the retraction settings would show in Cura, only they were ENABLED shows. I went to do my first print and sure enough, the printer was retracting out the maximum default value, at the maximum default distance and speed. This caused a fair amount of work to get the filament back into the print head while removing the Bowden Tube to trim the thin trail of blobs.
2) I went into the Materials , nGen and Customize to make sure the default retraction values were correct. They were not. I corrected and hit Store as Present to save them.
3) I am trying the 14 hour BB-8 print now. Sure enough, the retraction bug hit again. I again had to get the filament back into the print head and while the bed was heating, manually go in and correct the retraction distance and speed.
So...there's a few glitches in the process of using your own settings and Cura playing nice with them
drayson
Post by drayson »
Hi! I also made something similar but in excel... Up to now it works but have not so much prints with the new cura until now....
Cura is proving to be a challenge to work with, I am beginning to appreciate 15.04.2
Post by reibuehl »
I still use 15.04.6 for all my prints :)
I'm so used to having temp and retraction control from the UMO days. I'm still adjusting!
I am noticing that I loose my MATERIAL.TXT settings when the machine is powered back up after being off.
I have to keep uploading it from the SD Card despite following the instructions to Save
It could be that it will only hold the details of a number of materials, the older version would only hold 14 profiles. Try deleting a profile you don't use and see if it then retains your nGen settings
Someone commented elsewhere that it is a know issue. :(
Post by reibuehl »
Any settings for Ultimaker Flex-PLA and/or InnoFlex 45?
