BB-8 Frame print
Show us your latest print!
BB-8 Frame print
Post by LePaul » October 29th, 2016, 7:02 pm
14.5 hour print, first one on the Ultimaker 2+
Used glue stick and bed temp of 65 (first print flew apart 1 hour in)
Cura 2.3.0
I think I should try the 0.8 nozzle and cut the print time in half!
MTVDNA
Re: BB-8 Frame print
Post by MTVDNA » October 29th, 2016, 7:32 pm
Looks nice! How much more prints do you need before it's finished?
Post by LePaul » October 29th, 2016, 10:28 pm
Well....I need 23 more of those! And that's just the frame structure.
Printer donations welcome :)
I think it would be neat to do this in 0.8 1/2 the time and I wonder how good the details would be (holes, etc)
Post by Izzy » October 30th, 2016, 4:14 am
If you stick to the same layer height, and we're printing 4 skin thickness at 0.4 which you now print 2 skin thickness at 0.8 there should not be to much difference, I don't have much experience in the larger nozzles I play around with the smaller ones.
It's worth a try.
Izzy.
Post by LePaul » October 30th, 2016, 1:02 pm
This one was done with the ruby nozzle
Post by LePaul » October 30th, 2016, 4:33 pm
We'll 0.8 is a fail. It seems to keep clogging itself up
MTVDNA
Post by MTVDNA » October 30th, 2016, 4:41 pm
Maybe you need to increase the temperature a bit. If you print at the same speed and layer height, your flow is now twice as high.
Post by LePaul » October 30th, 2016, 4:54 pm
Also getting a clicking sound every 10 seconds
Went back to the 0.4 nozzle (non ruby) and similar problems.
Post by Izzy » October 30th, 2016, 4:59 pm
The clicking sound I think is your feeder skipping
Izzy.
Post by LePaul » October 30th, 2016, 7:46 pm
Well it must be a matter of tweaking settings for 0.8
I did a small calibration print...that came out fine. It seemed to take longer to prime the print head but eventually flowed well
Now we're a few hours into another 14 hour print.
danilius
Post by danilius » October 31st, 2016, 11:50 am
I find that with a 0.8mm nozzle I have to drop the temperature by 20 degrees in ABS, something close to that in PLA.
Titus
Post by Titus » November 6th, 2016, 8:15 am
Yeah, when I go to .8mm I increase the temperature by quite a lot too. Like 20-25 degrees.
