UM2 print head project
Re: UM2 print head project
I think that the englih source provide the PBI Duratron from this compagny : http://www.quadrantplastics.com/fr/cont ... /4741.html
May be you can try to contact them directely
- drayson
Thank you!
I found there a note - do you think this is relevant?
"Components rapidly exposed to temperatures above 400°F (205°C) should be "dried" prior to use or kept dry to avoid deformation from thermal shock."
Hi !drayson wrote:Thank you!
I saw this note, I think it concerns cases of storage or use in extremely wet condition, which is not our .
- drayson
@ Gudo,gudo wrote:Hi Drayson
Yes it's very very expensive![]()
as I said 12.7mm rod would be sufficient & less expensive,
if you really want test, purchase it ! I'll redeem you the rest
Sorry, overlooked your post/offer. Yes, would be a possibility, but currently I´m looking for somebody who is able to machine it...
Currently I redesign my idea to make it easier to manufacture.
Might there be a possibility that you assist at this point??
drayson wrote:@ Gudo,gudo wrote:Hi Drayson
Hi !
Yes Drayson ! no problem for the assistance, it will when you want
- drayson
Great! Thanks, I will keep you informed !
Now when the UM3 is official, maybe gudo understands why I asked him if he had been visiting the Ultimaker R&D
First this one:
And then these things, both the radial fans, the fan cap and the way it opens.
First this one:
Which is essentially what the more rigid bed of the UM3 does.gudo wrote: It is a outstanding project for optimize and rigidify better the overhang of the bed tray, with fine adjustable level rods, it's not yet completed.![]()
Hi to allAnders Olsson wrote:Now when the UM3 is official, maybe gudo understands why I asked him if he had been visiting the Ultimaker R&D
Anders ! I understand now why you asked me
It seems I was in the same R&D spirit
Not so far of the UM3 core removing
- drayson
I´m currently thinking how to change the UMO head design completely... so also my PBI parts design might change...
Gudo, do you think that the stainless steel/PTFE parts of the core could be made of PBI too? I have not ordered up to now but this might be a possibility to get down with the costs...
AAAhhhh... all this ideas...
b.t.w.: I completely forget to ask - where are you located, gudo?
Hi Drayson !drayson wrote: I´m currently thinking how to change the UMO head design completely... so also my PBI parts design might change...
With the few I seen here about the core, the hot end assembly is very similar to the known metal hot ends on market,
the PBI is a very effective heat insulator and ist's strong enough to make," I think", in 1 small diameter part for replacing the few core stainless steel/PTFE parts, the core heat block can be screwed directely on it.
To confirm when more details will be accessible
(Btw : I'm located in the West of Paris, 30Km after the Versailles castle)
- drayson
gudo wrote: ...
To confirm when more details will be accessible![]()
Greetings from Austria/Graz,
Chris
