Simplify3D vs Cura comparison
Re: Simplify3D vs Cura comparison
Right hand side 2nd and 4th buttons, or double click the part and you get the menu and you can input your numbers etc, you can even scale
I see that...but for more complicated parts, I just really prefer the GUI/being able to use the mouse to move it
I wish there was an UMO HBK profile
Really the basic profiles of s3d for any ultimaker are pure crapppp. The best think to start it's copy the settings from a normal wuality of old cura into s3d ad from there start to tune up and learn the gazillion settings
Not being into the programing GCode side I started with the S3d settings and tweeked from there and found it ok, still an improvement on the print quality.
I like the machine control panel just wish it would show the actual Z height or level.
- jonnybischof
Thanks for the awesome writeup!
I totally <3 the "tool change script" feature.
It looks like S3D has everything you could ever want (unless you want that super-easy to use cause no features Cura).
And frankly, if you're using a software for a month or two, you will get used to any quirky interface. That argument may be a concern when you do your first steps with it, but after a while you won't even remember that you were used to a different UI..
Btw I don't know the new Cura. Still using the old one and missing many features, but it's usually okay enough.
