How far should i keep my print above the Build Plate?
i think sometimes it warps the print if i'm too close. i also think if the print takes too long it makes the bottom Glossy.
any thoughts, tips or advice
thanks
Looking for Tips on Distance from Build Plate.
shadowpunk
- 3D Printer(s): Mars 3
Re: Looking for Tips on Distance from Build Plate.
I use the default 5mm and it works out OK. I know this is the minimum as you have to turn the part at an angle so there are no large areas printing.
If I can I have the part sitting on the Build Plate. You can still add supports.
Also the thickness of supports can make a big difference, if in doubt go thicker.
shadowpunk
thanks Lez0. i'll give those tips a tryLez0 wrote: ↑July 28th, 2024, 2:42 am I use the default 5mm and it works out OK. I know this is the minimum as you have to turn the part at an angle so there are no large areas printing.
