Hello all,
I use a Anycubic Kobra 2 Pro printer with Anycubic slicer SW.
There are some issues I would like to fix and don't seem to figure out which parameters to adjust.
The first issue is, that the smoothness of the print is not as perfect as I would like it to be. See first picture. I enabled ironing, which helped, but the result is still not smooth enough.
Ironing parameters: Flow rate: 10 %, Spacing between ironing passes: 0.05 mm.
The second issue is, that the bridge is quite thin, so that the print has openings there. See second picture.
Can someone give me a tip what to adjust?
Thanks in advance.
Smoothness and bridge issues
Re: Smoothness and bridge issues
How about to picture of the print?
Ironing is better for flat surfaces, curved, not so much
