Hi there,
for calibration I want to print just 1 (red) wall of this cube but I only can see 2 walls in cura with my pfrofile.
It should look like in image 1.png. In image 2.png it is the slice of the profile I attached. The file extension have to changed to .curaprofile.
Have anybody a Idea which parameter in the profile is wrong?
Cura aycubic profile
- Attachments
- MEGA X-PLA-V1.0 calibration cube.zip
- (3.03 KiB) Downloaded 509 times
Re: Cura aycubic profile
Well I added the described printer and your profile (both) say they are corrupted.
Better plan would be to attach your Project File (File -> Save Project) This way we can see you settings and the model all in one.
However, based on the second photo, it looks like that's a single wall print. I assume you're trying to dial in your flow rate?
