Extruder wont extrude Hitop 3DP12
Hello,
I'm at my wits end my Hictop 3DP12 wont print.
When printing the motor on the extruder just moves forward one tooth's distance and back one tooth's distance back and forth.
The nozzle is up to temp and not clogged I can push filament trough it fine.
I have replaced the motor, the wires, and the controller board. Using the move axis-extrude nothing happens even when hot.
It must be a setting someplace I'm missing.
Help,
Brian
Help,
Brian
Re: Extruder wont extrude Hitop 3DP12
I have two Hictop 3D Printers and have upgraded them the the max above ~ 3DP17
You may need to adjust your stepper motor V-Ref current,
Settings for My 3DP12 V-Ref current below for a 24 volt supply
X, Y, E0 and E1 = 0.395v // Only Date on Steppers - it has 6.2 ohms
Z Dual Stepper = 0.710v // 42SHD0026-20B Steppers
for a 12 volt supply
X, Y, E0 and E1 = 0.695v // 24HD4027-01 Steppers
Z Dual Stepper = 1.396v // 24HD2037-01 Steppers
Lets start with what filament are you using for your print. This filament has a temperature requirement for printing.
PLA ~ 190-220
ABS - 220-250
What slicer are you using if it is Cura 15.04.6 then Attached are my Cura profile presets. Included are 1.75 and 3.00mm filament.
I have the Nozzle Temperature set at 198C
With the LCD heat the Nozzle to the desired Temperature,
With the LCD try Extruding the filament
LCD Rotary know (Click)
Select Prepare (Click)
Select Move Axis (Click)
Select Extruder (Click)
Select 10mm (Click)
turn to Plus to extrude
turn to Minus to retract
PLA ~ 190-220
ABS - 220-250
Select 10mm (Click)
Last edited by Roberts_Clif on January 21st, 2019, 10:34 am, edited 1 time in total.
Really good instructions. What pins do I check the stepper current? And your numbers are volts, do you mean amps?
The voltage is measured from the trim-pots metal top adjustment.
I have placed a red arrow pointing at the pot adjustments below.
They are labeled R1, R2, R3, R5 and R6 on Base V1.3, MPK_V1 and MPX.3.
R1 is X
R2 is Y
R3 is Z : Double stepper higher V-Ref
R5 is E0
R6 is E1
R1 is X
R2 is Y
R5 is E0
R6 is E1
I have found that a Heat-sink is desirable on these controllers as the mosfets get hot.
I added a TO220 Transistor mounting kit and added an aluminum bar, along with a controller cooling fan.
Ok, measuring across these pins on the POT
I get 0.65 to 0.68 on all of the pots???
- Attachments
- POTimage.jpg (29.05 KiB) Viewed 44920 times
I'm using 1.7mm PLA .4 noz. and it oozes fine when pushed manually. I'll try your settings next
Your settings no joy. Trying to move extruder with Move Axis control, nothing. Will try swapping some motor connections.
Don't you have The 24V 3DP12 3D Printer, the X, Y and E's should work with a lower current. This will allow for a longer lifespan and cooler running.
I had my First 3D Printer 3DP11 the extruder motor was turning in the reverse direction. Be sure to test this using my previous post instructions.
I also have Chip Lucks Marlin Firmware updated for all Marlin 1.1.X versions you can read his original post here
He has a lot of good posts you should read on our 3D Printer.
Last edited by Roberts_Clif on March 29th, 2020, 10:17 am, edited 1 time in total.
The temperature of the Nozzle need to be 170C or better before the extruder will get power signals and is capable to movement.
It is a safety feature for no-cold extrude, which can damage the extruder components...
WORKING!
Was a bad stepper. First print not so nice a few blobs?
The Blobs could be caused by the Smooth rod holders.
The metal brackets that hold the Z steppers are too thin and allow movement in the smooth rods.
The X and Y belts could be loose and allow play causing the blobs.
These will also leave wavy lines on the X and Y edges.
Post a picture of your first print. Will look see if you can determine thew cause.
OK, here it is. I used your setting Hictop 1.75 Profiles 20.ini
Printer was set up on a card table, not sure if that was the most stable spot.
Thanks,
Brian
Thanks,
Brian
Double check and make sure Cura is set for 1.75mm filament.
Your extruder is under-extruding this could be because the filament is binding or getting tangled, the extruder gear is miss aligned,
the extruder spring tension is incorrect, or the Throat PTFE tubing has clogged causing a filament restricksion or you are
over/under driving the stepper causing it to miss steps.
Isn't your power supply 24 volts. If so your V-Ref settings could be over driving the steppers. Refer to my post above for approximate settings.
The Z-Axis has dual steppers in parallel that mean you will need approximately twice the V-Ref current to operate.
Unless they changed the electrical wiring since I bought my 3DP12 and wired the steppers in series then the V-Ref will all be the same.
