Object wall deormations
souci_saurus
3D Printer(s): Anet A8
Post by souci_saurus » February 7th, 2018, 7:58 pm
This has been happening for a while now, and pardon me if I'm being a total noob, but I haven't been able to quite figure this one out.
After slicing the objects, I see these deformities that look like divets and gaps in the walls, and sometimes parts are missing as shown below, sometimes compromising the integrity of the parts.
Picture attached.
I'm quite certain this is a Cura issue because I've sliced the same objects in other Slicers and haven't had this issue.
Thanks in advance
3D Printer(s): HICTOP 3DP-17
Re: Object wall deormations
Post by GrueMaster » February 7th, 2018, 10:06 pm
Which version of Cura are you using? What are the settings for wall thickness? Is there a link for the STL file?
Post by LePaul » February 8th, 2018, 8:52 am
I wonder of that is the Start/Stop location for each layer (perhaps random locations?) Perhaps the z seam?
MTVDNA
Post by MTVDNA » February 8th, 2018, 7:04 pm
I think you have coasting enabled. It's under the experimental features tab.
Post by LePaul » February 9th, 2018, 9:47 am
I usually have it on (coasting)...I'm curious how that would generate artifacts?
MTVDNA
Post by MTVDNA » February 9th, 2018, 4:09 pm
You can choose the coasting volume (or something similar, don't know the exact name), if you set it too high you get artefacts like this.
nallath
3D Printer(s): Ultimaker
Post by nallath » February 13th, 2018, 5:05 am
It's probably the z-seam location setting. Change it to shortest.
Return to “Cura”
Users browsing this forum: Baidu [Spider] and 1 guest
