UM2 Pinout Grafic?
UM2 Pinout Grafic?
Post by reibuehl » February 17th, 2018, 6:12 am
Does anybody of you have a PDF or grapic version of the UM2 Mainboard pin out? Or a version of Altium Designer to create one for me from the Altium files published by Ultimaker? A board view with the pins labled and if possible a schematic would be perfect but I would need to know at least where to find the PC7 (D30) and PD7 (D38) pins.
Reiner.
Re: UM2 Pinout Grafic?
Post by reibuehl » February 17th, 2018, 9:35 am
I found an older schematic, but that looks like the pins I thought could be used are different than what Marlin expects... is there a digital pin free that could be used for a filament sensor?
Reiner.
Post by reibuehl » February 17th, 2018, 10:09 am
Looks like I found my pins on the EXT/IO header:
Reiner.
jonnybischof
Post by jonnybischof » February 23rd, 2018, 3:05 am
Is 2.1.1 still up to date?
I use Altium Designer at work, so I can open the original source files and make any kind of documentation output you want...
Best regards,
Jonny
Post by reibuehl » February 23rd, 2018, 4:20 am
The latest version for the UM2 and UM2+ is 2.1.4 which can be found in git.
It would be great if you could create an updated PDF for that version, @jonnybischof. Schematics, top/bottom Silkscreen and maybe the top/bottom 3D view would be perfect. I do not need the copper layers or such. Maybe a parts list, too if that is not too much work?
Reiner.
jonnybischof
Post by jonnybischof » February 26th, 2018, 3:00 am
Ok, working on it.
Can do even better documentation, Altium has a new (for some time now) documentation tool which is really awesome.
Will use this occasion to do some "training" with the tool ;)
Best regards,
Jonny
jonnybischof
Post by jonnybischof » February 26th, 2018, 6:02 am
Done.
Now let's see if the forum lets me upload all that stuff...
Looks like it does <3
Ultimainboard V2.1.4 Bill of materials.xlsx
(17.97 KiB) Downloaded 202 times
Bill of materials. Unformatted (takes a lot of time). I just took those fields that made sense. The database is not very tidy so I didn't want to put too much effort into it.
Ultimainboard V2.1.4 schematics.PDF
(1.59 MiB) Downloaded 279 times
Schematics, PDF export of original files
Ultimainboard V2.1.4 PCBA overview.pdf
(151.52 KiB) Downloaded 211 times
Documentation output showing the connections and pinout
Ultimainboard V2.1.4 PCBA dimensions.pdf
(103.42 KiB) Downloaded 139 times
Documentation output showing the PCB dimensions
Ultimaker_V2.1.4 3D step.zip
(2.81 MiB) Downloaded 114 times
3D step export
If you need anything else, just ask ;)
Best regards,
Jonny
Post by reibuehl » February 26th, 2018, 6:37 am
Wow! Very nice job! I love the detail magnification of the pins. Many thanks! I wonder if Ultimaker would accept a git pull request with these files :-)
Reiner.
