Page 2 of 2
Re: Not enough material extruding before print
Posted: April 25th, 2017, 11:07 am
LePaul wrote:Or....let Ultimaker fix it so it works right for everyone :)
'Let Ultimaker'
'Works right'
Man you could be a USA president
Posted: April 25th, 2017, 2:44 pm
by Izzy
Quick question, do you have the i2k washer fitted?
If so check the diameter of the hole and the form of the retracted filament.
I had a similar problem, increased the hole diameter in the i2k a very little and problem solved.
Posted: April 25th, 2017, 3:47 pm
by reibuehl
I have mine removed already.
Posted: April 25th, 2017, 4:09 pm
'Let Ultimaker'
'Works right'
Be very, very careful with your insults. First warning :) :P
Posted: April 25th, 2017, 7:11 pm
by Anders Olsson
I just checked my UM2E, which does NOT suffer from this issue (at least not with files sliced in Cura 15.04, but as I recall it it works as it should with Cura 2.x too).
It is running on the 15.04ex firmware, so you could try that.
When thinking about it I probably only had this issue after upgrading the firmware using Cura 2.x.
As I can recall, none of the tinkergnome firmwares suffered from the retraction issue, which probably explains why the issues disappeared on my UM2Go
Posted: April 26th, 2017, 12:30 pm
Thanks for the information
Since the UM2E's are on loan, I don't want to put Tinkergnome's firmware on them.
I also recall there was an issue of some sort with it a while back?
Posted: April 26th, 2017, 12:47 pm
by Anders Olsson
Yes, the last versions of the tinkergnome has an elusive bug that makes the printer stop every now and then.
I hope they can find it soon, because it is a great firmware apart from that.
Installing 15.04ex from old Cura should be safe though, just upgrade the firmware with new Cura before you return the printer :-)
Posted: April 26th, 2017, 3:34 pm
Yes, we don't want pauses!
Asides having to use the Move Material and Materials.txt not working...I can live with that until they remedy it. :)
