Tom's E3D V6 hot end replacement for the Ultimaker 2 clip
Post by LePaul » December 1st, 2016, 2:12 pm
Interesting!
Re: Tom's E3D V6 hot end replacement for the Ultimaker 2 clip
Post by Neotko » December 1st, 2016, 2:47 pm
As a paid promo is nice. But what are the advantages apart of a bit higher temps? Isn't like normal people can actually print at that temps since 80% of the high temp filaments release nasty chemicals.
Also I would like to see an actual vs print and high retraction test using pla with that fullmetal stuff.
Post by LePaul » December 1st, 2016, 2:50 pm
I was going to mention that...show me a print after all of that! Let's see if it's better, worse or the same as the 2+ upgrade!
Post by Izzy » December 1st, 2016, 5:00 pm
So do we know how this comparison with the Olson block or the matchless?
And how does the feeder compair tomthe Bondtec performance wise?
Post by Meduza » December 1st, 2016, 6:16 pm
The feeder is probably about on par with the 2+ feeder, and re the hotend i would prefer the Olsson block any day over the V6, swapping nozzles is horrible to do when you have to hold the block steady with one tool to not damage the heat break and remove the nozzle with a tool in the other hand while the whole assembly is hot. Also the UM2+ setup with the TFM coupler is much better than a All-metal hotend for printing PLA.
Post by LePaul » January 25th, 2017, 10:19 am
I noticed in today's email flier from Matterhacker they are advertising it as being 'cheaper than the Ultimaker 2+ Extruder upgrade'
https://www.matterhackers.com/store/pri ... pgrade-kit
But they really don't mention the troubles of PLA or demonstrate how "easy" swapping those nozzles will be, versus the Olsson Block
