Cheap way to make it a LITTLE quieter...
Post by LePaul » December 5th, 2016, 9:59 am
With two printers on one table, I was noticing how the UMO really shakes, rattles and rolls
That might be good for Elvis music, not so much for the prints or neighboring printer :)
I happened to have some rubber drawer liner that I planned to use inside the toolbox drawer for tools to rest on.
I cut a small piece, folded it in half and placed under each corner of the printer. I also did the same for the neighboring printer.
It seems to have helped some and is a pretty inexpensive tweak.
Re: Cheap way to make it a LITTLE quieter...
Post by Amedee » December 5th, 2016, 10:25 am
Ninjaflex feet...
Phil.
Titus
Post by Titus » February 17th, 2017, 11:51 am
Daym! I had feet(gijs), but printing them in flexible is smart!
And that design looks nicer than Gijs' tbh. Then again Gijs used rubber bands to get it working, this design doesn't require that!
Do you have a link :D?
Post by ivan.akapulko » February 19th, 2017, 4:47 am
Something such as yoga mat?
jonnybischof
Post by jonnybischof » February 20th, 2017, 2:42 am
I'm using a set of foam cushions you can buy to stick onto sharp edges so your kids don't get hurt when they bump into them. Don't ask me how that is called properly in english :P
Cost me around 10$ and they fit the UMO corners perfectly. The foam density is very good to absorb vibrations. Has been in use for more than two years now...
/edit:
Here's a link to what I mean:
http://www.babyjoe.ch/Sicherheit/Sonsti ... oC6cHw_wcB
(That baby on the page kinda freaks me out tho o.O)
Best regards,
Jonny
Frederik
3D Printer(s): Ultimaker Original plus
Post by Frederik » February 24th, 2017, 7:53 am
Hello new forum!
First of all, some OT appreciation to whoever set this up as a new haven for the lost souls of the former UM community! (That would be LePaul?)
THANK YOU!
Now on to the topic:
I made a design to decouple the feeder from the printer frame about two years back, when I got my UMO+. It is still hosted on YouMagine atm and can be found here: Feeder Damper
It is an easy to install drop-in, you just need a zip-tie, or some wire to attach.
Overall, the TPU materials seem to break down a little over time, losing some degree of softness. However I did not feel the need to replace my print in two years. There was still some residual humming which I could get rid of by placing a small piece of foamed plastics (that mattress like stuff used for packaging electronics) under the bottom part touching the backplate.
At least with my UMO+ I found that most of the noise was produced by the stepping of the feeder resonating on the backplate acting as a "drumhead".
Rubber feet come in handy none the less :)
Regards,
Frederik
Post by LePaul » February 24th, 2017, 9:42 am
I'm guilty of building the forum :) But I point out that Anders nudged me into it!
Post by LePaul » February 24th, 2017, 9:58 am
p.s. hope you find your way into the Simplify 3D area!
MoonCactus
3D Printer(s): many of them
Post by MoonCactus » March 3rd, 2017, 3:11 pm
Titus wrote:Daym! I had feet(gijs), but printing them in flexible is smart!
A bit late but since I just opened an account ... I designed feet that looked quite similar in 2012 (printed in UM soft PLA):
http://www.thingiverse.com/thing:25438 (yep sorry, never took the time to move my things elsewehere)
Use the customizer to set the height!
Post by LePaul » March 3rd, 2017, 3:21 pm
That's a good idea. Lord knows my Ultimaker Original is so loud, you'd think there's a haunting underway from upstairs.
