Temperature control & fan speed
Post by Amedee » May 10th, 2016, 5:30 pm
I have an issue with my UMO that I didn't notice before (it might not be new, but I never noticed it before).
When I use the fan at a low percentage I cannot get a stable temperature...
I did some test with a print this evening, temperature set to 225°C.
- Fan off: after 2 or 3 oscillations, it sticks on 225°C and doesn't deviate anymore
- Fan 10-20%: it never stabilize jumps between 222 and 228°C!
- Fan 50%: a bit more stable 224-226°C
- Fan 100%: stable at 225°C, no deviation
I may be completely wrong, but I have the impression that the PWM fan influences the sensor.
Anybody already seen that?
(It is an old 1.5.3 board with thermocouple)
Phil.
Re: Temperature control & fan speed
Post by Neotko » May 10th, 2016, 5:57 pm
The test was done with the bed making the air bounce on the block? I suppose not, so it's really weird I suppose. I know very very little of the 1.5.x boards.
Post by LePaul » May 10th, 2016, 7:54 pm
I've only run 100% fan but tonight I plan to try out XT-CF20 with No Fan...I'll see if the temp bounces around
Post by LePaul » May 10th, 2016, 9:02 pm
I'm printing now. No fan. Temp set to 256 and seeing it bounce around from 255 to 257. Nothing wider than that so far!
martin-bienz
Post by martin-bienz » May 11th, 2016, 2:54 am
Amedee wrote: Anybody already seen that?
Well, yes. I have that also. I think since the beginning. I just ignored it / accepted that PWM is messing with the sensor. I allways see it at the beginning of prints as the fan slowly starts up... I am pretty sure it's PWM and I assumed this is "normal". I see that because I sometimes have to manually help the fan to start in the beginning ... after the first layers when the fan kicks in fully, no issue.
I have never looked at it in detail... will try to the next print. But I am again off a few days (congress).
Post by Amedee » May 11th, 2016, 3:13 am
Yes, I guess I never noticed before because it is common that when you start the fan the nozzle needs to adjust a bit.
What made me looked more in detail is that nowadays i tend to use very little fan and it stays in the 10-20% range while in the past it would just have been a transition...
Phil.
