Creality Cr-10s Help Please
Creality CR-10 series 3D printers
grantknight
3D Printer(s): Creality Cr-10s
Post by grantknight » June 15th, 2018, 12:08 am
Hi All
I have a Creality CR-10s printer which has been working fantastic with no problems recently until suddenly i wanted to print, inserted the SD card selected the print, nozzle goes to temperature but the bed does not heat up and when the print begins it ends immediately without printing. I have reformatted the SD card and tried a new SD card with the same results, reinstalled Cura 3.3.1 on my laptop with no luck. I can change anything manually on the printer ie steppers move, nozzle temp, bed temp....any ideas?
Re: Creality Cr-10s Help Please
Post by LePaul » June 15th, 2018, 10:28 am
A few questions ...
Have you checked the wires going to the bed? Are they attached? Coming off?
I would want to be sure the hardware is OK
Post by GrueMaster » June 15th, 2018, 10:31 am
Have you tried reprinting a known good print from your SD card? Have you tried printing from USB? You said your bed doesn't heat up. Have you tried to heat the bed manually from the controller menu (Prepare->Preheat PLA->Preheat PLA Bed)? How does the wiring on the bed look? Do you have the highly recommended wiring harness strain relief bracket?
Return to “Creality CR-10 Large Scale 3D Printer”
