Remote viewing only? (For CNC Machine)
Posted: April 6th, 2016, 12:39 pm
So after a few weeks of working on the CNC machine each night, I am wondering about a remote viewing, similar to OctoPrint.
The machine takes about 1 hour to create the aluminum part I am making. I usually set my timer and come back every 20 minutes to make sure the end mill hasn't broken and check the quality of the work.
Being it is cold out still, it would be nice to station a web cam on the machine and remotely view a live stream of how it is going!
Ideas?
Re: Remote viewing only? (For CNC Machine)
Posted: April 6th, 2016, 12:53 pm
by Izzy
If you have an old iPhone or iPod with camera, there are two apps, iCamSource & iCam Pro that allows you to set the 1st as the source camera and monitor on the other.
Posted: April 6th, 2016, 1:32 pm
I do have an old iPhone 4 I could purpose for that. But then I need to find a secure base/mount :) Always something
Posted: April 6th, 2016, 2:44 pm
by Izzy
If only you could design and make something :roll:
Posted: April 6th, 2016, 2:50 pm
Printer is down...
Posted: April 6th, 2016, 7:16 pm
by Meduza
Then CNC mill it ;)
Or take a raspberry pi with a raspberry pi camera and install MotionEyeOS: https://github.com/ccrisan/motioneyeos/wiki
Or just get at cheap ip camera, those are 20$ and up on eBay and are complete self-contained units.
Posted: April 13th, 2016, 9:52 am
Thanks for the link...every lead helps!
Posted: April 14th, 2016, 4:06 pm
Izzy wrote:If you have an old iPhone or iPod with camera, there are two apps, iCamSource & iCam Pro that allows you to set the 1st as the source camera and monitor on the other.
iPhone 4 doesn't have iOS 8 (only 7.x) Nuts
Posted: April 14th, 2016, 4:46 pm
by Izzy
Sorry about that, it works well but you need to keep it plugged in as it drains the battery, I may look into the Raspberry Pi solution
Posted: April 15th, 2016, 3:13 am
by Amedee
I'll second Meduza here: don't over-engineer it.
A cheap IP cam and you will be good to go.
Raspberry Pi is a nice toy, but if you add the Pi, the cam, the SD-Card and the power supply it will cost you easily $80 which is more than a Foscam Full HD IP cam with IR illumination -- not to speak about the very cheap ones from the Bay...
Posted: April 15th, 2016, 8:36 am
IP cam....hadn't thought of that (which I thank you for the idea!)
Posted: April 15th, 2016, 10:13 am
by Meduza
Get something like this:
http://www.ebay.com/itm/171768316636
Posted: April 15th, 2016, 10:19 am
by Amedee
Or their indoor models (like the Foscam C1) which are less expensive...
Posted: April 15th, 2016, 4:36 pm
by reibuehl
Be careful with the newer Foscam cameras. Their app stores admin password, device ID and MAC address of the camera on a Foscam server and with this information, it is also possible to get the SSID and password of your wireless network. In addition, their IOS app apparently doesn't correctly validate SSL certificates so that you can exploit it with a man-in-the-middle attack. Unfortunately the article where I read it is only available in German, but for those of you who like to see the article, let me know - or buy it here :-)
Posted: April 19th, 2016, 9:52 am
Ugh Goole translated the page but like most translators, it is not coherent. I'll let someone else summarize :)
