Controller Freezes
Re: Controller Freezes
Post by Roberts_Clif » January 1st, 2018, 8:40 pm
I like, and have downloaded lots but did not like them. and have not had time to use Fusion 360 for my own design.
I have wanted the display off the top for a long time. I believe i get noise from the controller the interferes with the SD card.
Did you ever try my Snap together Controller case.
thank you.
Post by GrueMaster » January 2nd, 2018, 10:00 am
No, because my controller is in a metal case already. I have it, just haven't had the need to use it.
Post by Roberts_Clif » January 2nd, 2018, 10:34 am
That's correct! I remember now! we Forget the small things sometimes.
Post by Roberts_Clif » January 5th, 2018, 4:23 pm
Found my problem. My new MPX.3 Backup controller from Hictop is Bad. Replaced with the Original Base v1.3 controller Flashed Marlin 1.1.5 worked perfect. Contacted Hictop will not talk to me, will not message me.
Printed the LCD case for Blu. Now will do some testing to see if any problems arise.
Printing a pop bottle bird feeder on my New Surface from Hictop Rep so far only build surface that has worked besides Vinyl transfer Paper Tape.
I like the Front LCD though, have not officially decided if I like the LCD style or not. Believe may re-mix it and post here for others.
Post by Roberts_Clif » February 1st, 2018, 7:56 pm
Last note on the blog, Contacted manufacture they agreed to replace controller under warranty.
Replacement has been shipped and will arrive here when is can pass thru U.S. Customs.
Return to “General Questions”
