Weird printing errors
Posted: June 10th, 2016, 1:35 pm
I've been reading lots of posts and haven't seem to find a solution so some of the problems I'm having.
I've got the HIC Desktop printer DIY kit.
Everything was going great for the fist few weeks. PLA prints only. Print quality was great. Printing only gcode from SD card. Learning lots and tweaking some things through Cura. Very cool. Reading lots as well here on this forum. Lots of learning.
About a week ago i started getting BAD printing errors.
1. At random times during the print the printer head will print a random line that shouldn't even be there. Sometimes a long horizontal line outside of the perimeter box (outline) extending all the way to the end stops, then back. Sometimes a random diagonal line on the print itself at a random angle or runs over an area where no material should be.
2. Extruder has sufficient flow only SOME times during print (at all temps between 190-210 for PLA). When manually extruding by .1mm there's some clunking noise and stepper motor doesn't feed well and flow is a trickle. Manually extruding at 1mm flow is much better but sometimes clunking noise and flow stops to almost nothing. (I've changed nozzles twice)
3. Random z axis shifts. During a few prints, the Z axis has shifted up by 1cm or more and started printing the next layer.
Not sure if there is some catastrophic firmware issue and need to reset/upload new firmware (i've read all posts in that vein).
Any ideas?
Thanks,
Jon
Any ideas?
Thanks,
Jon
