Hictop Upgrades
Ctx32
3D Printer(s): Hictop
Hictop Upgrades
Post by Ctx32 » June 15th, 2016, 9:58 pm
So, My printer is going through some changes to get this printer up to it's max.
Everything from the power supply to the basic screws.
The Hictop in stock form is very capable in producing good prints but there's always room for improvement in any brand of printer.
My goal is to get this $230.00 printer to compete with the high dollar printers.
I have uploaded Chip's new firmware and it is working great, I will be fine tuning it as far as I can to fit the Hictop only.
I have a YouTube friend that has trusted me with his Hotend Carriage design for the E3d V6. This carriage has been tried and trued by him and he is constantly improving his designs.
I'm using at this time a Bowden extruder I found on Thingiverse. Not sure at this time if I will continue on with it or opted for another design.
I also have Linear Screws on order and will add them at a later date.
I've also found Z mounting ends on Thingiverse that are improved versions of the Hictop and will fit the Linear Screws.
Anyway, More to come. Failures will happen but that's how it goes.
Chip Luck
Re: Hictop Upgrades
Post by Chip Luck » June 16th, 2016, 9:08 am
Good stuff. Let us know how it goes with the upgrades.
Ctx32
Re: Hictop Upgrades
Post by Ctx32 » June 16th, 2016, 9:48 pm
Little update.
I actually started a print today.
I have to reprint the base for my extruder so I can add the Bowden locks, It pushed the tube out.
I did have to change my firmware to a modified stock version.
Chip's firmware is awesome but it's set for a stock or his printer, All the changes in hardware on mine caused problems.
My extruder was offline and couldn't get it running so I uploaded my own version of firmware.
I did take allot of changes Chip made to the software and incorporated it into mine.
Would have taken much longer without Chips for a base.
The short print was not enough to even show a picture but I can already tell the print is much better than the stock hotend.
Once this printer is running 100%, I'll modify my other Hictop to match and then add the Linear rods to this one to improve on the
Z banding.
This little print is on it's way to AWESOME!!!
Chip Luck
Re: Hictop Upgrades
Post by Chip Luck » June 17th, 2016, 8:59 am
Calvin, do you have the source for the modified stock version? All you have to do is go through the Configuration.h file and apply any changes to the one I'm using and you should be good to go. If you have the firmware source, send that to me or .zip it up and post it here, I'd like to take a look at it.
Ctx32
Re: Hictop Upgrades
Post by Ctx32 » June 18th, 2016, 6:02 pm
Progress,
Here's a link to the video of the printer on Ebay.
Still more to do.
Ctx32
Re: Hictop Upgrades
Post by Ctx32 » June 22nd, 2016, 3:47 pm
Ugly and all over the place
Now under control.
I need to add the fan but that will come later.
Chip Luck
Re: Hictop Upgrades
Post by Chip Luck » June 23rd, 2016, 8:28 am
Looks great, keep up the good work and thanks for sharing.
Ctx32
Re: Hictop Upgrades
Post by Ctx32 » June 25th, 2016, 3:08 pm
More pics of various upgrades.
I'll explain each after I get everything complete and I post links to all of these.
I'm not just randomly adding each upgrade just for the looks, Each has a purpose and makes the Hictop a better and easier printer to work.
RednKentucky
3D Printer(s): Hictop Migbot
Re: Hictop Upgrades
Post by RednKentucky » June 25th, 2016, 11:17 pm
I like how you put your end stop. I need to do that one.
JoelR
Re: Hictop Upgrades
Post by JoelR » July 8th, 2016, 10:34 pm
May I suggest taking the quad-y-linear bearings to the next step? I upgraded to supported 12mm with adjustable bearings and won't go back. I loose some z height, but the bed is rock solid with no play. Next will be ballscrews for the z-rails and a dual bowden setup for the print heads. People forget that extra weight on top leads to perimeter waves. Worst thing to do is run fast with a full spool on the top of the printer.
Chip Luck
Re: Hictop Upgrades
Post by Chip Luck » July 15th, 2016, 11:35 am
JoelR wrote:May I suggest taking the quad-y-linear bearings to the next step? I upgraded to supported 12mm with adjustable bearings and won't go back. I loose some z height, but the bed is rock solid with no play. Next will be ballscrews for the z-rails and a dual bowden setup for the print heads. People forget that extra weight on top leads to perimeter waves. Worst thing to do is run fast with a full spool on the top of the printer.
So, you are saying that a full spool of filament on the OEM rack on top will induce waves? Interesting and could be true. Sort of like a improperly bedded/supported rifle barrels harmonics/wave throwing off a projectile POI...
rellik1000
3D Printer(s): CR7,Hic Al i3
Re: Hictop Upgrades increase printing speed?
Post by rellik1000 » August 4th, 2016, 4:22 pm
This was my first printer a CR-7 https://m.aliexpress.com/item/32505584402.html purchased about a year ago.
150x150x120 PLA only,no heat bed,minimal footprint.
FYI PLA can print fine with no heatbed.
Funny... my son taught this to his CAD/tech instructor,with their $3500 3dp.
The beauty of DIY.
It is a really great entry level 3dp.
Kinda looks like a toy but is a full blown printer.
I learned a lot building and tweaking this thing.
A little bummed out though,I expected the Hic aluminium i3 to be an upgrade.
Using my tweaked CR-7 slic3r/repetier settings as a baseline for the Hictop it sounds like it's going to explode.
I have to bump the feed rate down to 80% or less to print without any grinding or growling noise.
Everything has been realigned/retightened three times now.
The Hic prints nice,just slowly
My little CR-7 can print almost twice as fast with equaled quality.I can bump the feed rate to like 150% or more to quick print pieces without fine detail.
I already did a bowden mod to reduce the mass of the x carriage.
I'm looking for other mods to increase the print speed.
Rebuilding the world.....
One layer at a time
Chip Luck
Re: Hictop Upgrades
Post by Chip Luck » August 4th, 2016, 7:59 pm
I run about 40 to 50mm/sec max print speed for 'detail' parts, non-printing feed rate of about 200mm/sec, all accelerations capped at 1200. I'm happy with mine, it's no speed demon, but it has printed perfect a '3D Benchy', 'Ulti'robot', test objects et. all at 0.1mm height with outstanding results. Considering it was ~$300 delivered and having to put in some a few more $ for basic and need upgrades (updated PSU, some linear bearings, z-rods, etc.) and modifying the firmware and 3 months of time tweaking it, well this thing has served me well so far. I have no regrets, it's a learning curve. One day I will get a 'real' printer, but if I want a basic and cheap do it all 3D machine, I'd buy more HIC i3's in a millisecond.
NotMe999
3D Printer(s): HICTOP Prusa i3 with Auto-leveling
Re: Hictop Upgrades
Post by NotMe999 » August 13th, 2016, 8:13 am
After getting the shipped HICTOP printer working well, with much thanks to Chip, I worked on getting dual extrusion using the Chimera from E3D Online. Many attempts at a 3D Printed Mount to adjust my design (have a colleague who also has a 3D printer, so I didn't have to keep taking apart mine), I got a good design only to find it warped when I heated up the extruders. After 5 weeks of waiting on the fab shop, I got a metal x-carriage, and now have the dual extrusion working. I still need to tweak a bunch of settings (using Marlin 1.1.0-RC6), but the dual extruder test cross shows the head alignment is good. Found a nice picture showing the pin designations for the MKS v1.4 so I could power both hot ends and the cooling fan. Changed to Bowden extruders to make the implementation easier.
NotMe999
Re: Hictop Upgrades
Post by NotMe999 » September 10th, 2016, 5:57 pm
Update. Got the heads as close to level as I can get. Printing good quality. New PID settings for new hot ends and new temp settings for hot ends for the thermistors that come with the chimera. Here's a closer picture of the x-carriage mount.
Recommend the Dual Extruder Calibration Cross .4 mm nozzle if going to Dual Extrusion with 0.4 mm nozzle.
http://www.thingiverse.com/thing:1023194
Here's a picture after a few changes to the X offset in the firmware. Apparently my x-carriage puts the nozzles about 0.3 mm of in the x direction. Still using 18 mm on the y.
