I'm trying to enable mesh bed leveling via #define MESH_BED_LEVELING in marlin 1.6.1. I've hot a hictop i3 with an aluminum plate bed that is warping just enough to blow my prints and make manual leveling impossible.
When I go to prepare>bed leveling, the printer performs the auto-home sequence, hitting 3 endstops and the that's it.
Any idea what I'm doing wrong here?
manual MESH_BED_LEVELING howto?
Re: manual MESH_BED_LEVELING howto?
I do get an 'Err: Too far!'
ok, so I figured it out, had an uncaught error in the comment of LCD bed-leveling...
but now that I have your attention..
I'm running through the bed leveling routine using a piece of paper as the guage. setting it just above where the paper grabs. This is how I've been manually leveling printers for a long time.
I save those settings and then run a print. The print head is riding right on the bed, no gap. As if the bed leveling offsets weren't being used.
If you are not saving your bed leveling offsets, you should. after bed leveling is complete save the offsets using M500 or Store settings.
After you have stored the settings. In you Cura start/End-GCode place this line after
G28 X0 Y0
M420 S ; Bed Leveling On
M420: Enable/Disable Bed Leveling and/or set the Z fade height.
S[bool] Turns leveling on or off
Z[height] Sets the Z fade height (0 or none to disable)
V[bool] Verbose - Print the leveling grid
This Allows you to view bed leveling data.
> M420 V
< Bilinear Leveling Grid:
< 0 1 2 3
< 0 -0.135 -0.043 -0.100 -0.267
< 1 -0.150 -0.015 -0.008 -0.160
< 2 -0.152 -0.015 +0.005 -0.127
< 3 -0.210 -0.085 -0.040 -0.135
< 4 -0.227 -0.133 -0.118 -0.192
< echo:Bed Leveling Off
< echo:Fade Height Off
This turns on you bed leveling data, so it can be used.
> M420 S
< echo:Bed Leveling On
G28 X0 Y0
> M420 V
< 0 1 2 3
> M420 S
Question on bed leveling. What is the action that happens at the printer when a bilinear bed leveling is performed? I had one version of firmware that probed up and down in a grid pattern, but it was an 8x8 grid, even when in the firmware I had it being a 4x4. I made other changes to my firmware that I didn't think were related to the bed leveling and now I get a 4x4 grid, but the probe doesn't go up and down in the z axis at all. The z axis raises and lowers in the top left corner (as you look at the printer) and then the grid starts and goes left to right, moves the y backwards, goes right to left, etc, creating a 4x4 pattern, but again, the z never raises or lowers. Here is the output from my latest bed leveling
17:28:43.260 : Bilinear Leveling Grid:
17:28:43.277 : 0 1 2 3
17:28:43.277 : 0 -0.010 -0.008 -0.005 -0.003
17:28:43.281 : 1 -0.013 -0.015 -0.018 -0.020
17:28:43.281 : 2 -0.163 -0.160 -0.158 -0.023
17:28:43.282 : 3 -0.165 -0.168 -0.308 -0.310
17:28:43.282 : X:201.00 Y:140.00 Z:1.13 E:0.00 Count X:16080 Y:11200 Z:440
Bi-Linear bed levels, first Auto Home or G28 will not level-bed unless homed.
Then select Bed leveling or G29. I have a 4x5 grid, First home and lowers then raises 4 times across the front of the bed from Y-min to Y-max.
Then moves back to second row and again lowers then raises 4 times across row 2. from Y-max to Y-min
Ect... to the end of bed.
I do a G28, then G29 and it use to raise and lower at each grid point, but now my firmware no longer does that. I am not sure why. Could this by why?
#define Z_CLEARANCE_DEPLOY_PROBE 0 // Z Clearance for Deploy/Stow
#define Z_CLEARANCE_BETWEEN_PROBES 0 // Z Clearance between probe points
// For M851 give a range for adjusting the Z probe offset
#define Z_PROBE_OFFSET_RANGE_MIN -20
#define Z_PROBE_OFFSET_RANGE_MAX 20
Okay, got it. It is this
The Z_CLEARANCE_DEPLOY_PROBE value needs to be such that the z axis raises so the sensor doesn't trigger when when taking a reading. The world is now good for my auto bed leveling.
