Marlin 1.1.5 Saving Bed Leveling Data
Posted: September 22nd, 2017, 8:41 am
To Level bed we use " G29 ", M500 to save the Data to EEProm.
After Bed data is saved you request Bed Leveling be turned on.
you add the command " M420 S1 " after last " G28 " in Start G-Code.
M420: Enable/Disable Bed Leveling and/or set the Z fade height.
S[bool] Turns leveling on or off
Z[height] Sets the Z fade height (0 or none to disable)
V[bool] Verbose - Print the leveling grid
G28
X:100.00 Y:110.00 Z:10.50 E:0.00 Count X:8000 Y:8800 Z:16800
G29
My Bi-Linear Bed Data ; Wow bed is not as level as I thought.
< ----0--------1---------2
< 0 -0.123 +0.082 +0.095
< 1 -0.260 +0.002 +0.017
< 2 -0.025 -0.025 -0.160
Restart 3D Printer
> G28
< X:100.00 Y:110.00 Z:10.50 E:0.00 Count X:8000 Y:8800 Z:4200
> M420 V ;Send a M420 V ; Print the leveling grid
< Bilinear Leveling Grid:
< echo:Bed Leveling Off
< echo:Fade Height Off
> M420 S1
< echo:Bed Leveling On
Just an FYI
G28
G29
Restart 3D Printer
> G28
> M420 S1
Just an FYI
