printer totally a mess and i cant seem to sort it
dmkmedia
3D Printer(s): Hictop persia
Post by dmkmedia » February 18th, 2017, 1:32 pm
have a HicTop hictop prusa i3 aluminum from china printer and was told to update the firmware. ever since then it not printed anything right after reading trough the forums here, i have managed to get it printing but not correctly.
the printer starts off on a test print of a 20mm shape its ok when doing the raft then once it starts to do the shape
the z axis moves up to fast on each slice so i just get a spiral of filament spinning off the raft
and if i do actually get it to do anything near printing when the nozzle lifts up it leaves a string of filament and it all mounts up to a spiky mess.
i am using marlin viewtopic.php?f=51&t=298
and was advised to use repetier server so i have bought it and still cant get a solid print from the machine.
i also have auto bed leveling. even that isnt working correctly it does the levling thing and one side is about .5mm out
 * REV: 06.13.16, HICi3-1.1.0-RC6-Bugfix, downloaded from Github archive.
 * A custom configuration.h for HICTOP Reprap Prusa I3 "Ebay aluminum frame/Florida BB-8 Builders discount version"
 * Major Changes and Updates from Marlin default:
 * 1) Motherboard type changed for 'red' HICTOP 'MPX.3' RAMPS 1.3 control board (Power Outputs: Extruder, Fan, Bed) = !check your verison!
 * 2) Enabled discount 4x20 LCD controller with rotary control
 * 3) EEPROM enabled
 * 4) SD card support debuged, need to continue testing
 * Source files changed from original distro.  Original files names will follow with an *.orig tag:
 * - Configuration.h // this file
 * - Version.h // edited version file for reference
 * All changes form original Marlin supplied source code is documented for this printer.
 * NOTE: to search for actual changes for my HICi3 printer changes here, search for 'CL:'
 * Marlin 3D Printer Firmware
 * Copyright (C) 2016 MarlinFirmware [https://github.com/MarlinFirmware/Marlin]
 * Based on Sprinter and grbl.
 * Copyright (C) 2011 Camiel Gubbels / Erik van der Zalm
 * This program is free software: you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation, either version 3 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program.  If not, see <http://www.gnu.org/licenses/>.
 * Configuration.h
 * Basic settings such as:
 * - Type of electronics
 * - Type of temperature sensor
 * - Printer geometry
 * - Endstop configuration
 * - LCD controller
 * - Extra features
 * Advanced settings can be found in Configuration_adv.h
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
#include "boards.h"
#include "macros.h"
//============================= Getting Started =============================
 * Here are some standard links for getting your machine calibrated:
 * http://reprap.org/wiki/Calibration
 * http://youtu.be/wAL9d7FgInk
 * http://calculator.josefprusa.cz
 * http://reprap.org/wiki/Triffid_Hunter%27s_Calibration_Guide
 * http://www.thingiverse.com/thing:5573
 * https://sites.google.com/site/repraplogphase/calibration-of-your-reprap
 * http://www.thingiverse.com/thing:298812
//============================= DELTA Printer ===============================
// For a Delta printer replace the configuration files with the files in the
// example_configurations/delta directory.
//============================= SCARA Printer ===============================
// For a Scara printer replace the configuration files with the files in the
// example_configurations/SCARA directory.
// @section info
#if ENABLED(USE_AUTOMATIC_VERSIONING)
  #include "_Version.h"
#else
  #include "Version.h"
#endif
// User-specified version info of this build to display in [Pronterface, etc] terminal window during
// startup. Implementation of an idea by Prof Braino to inform user that any changes made to this
// build by the user have been successfully uploaded into firmware.
#define STRING_CONFIG_H_AUTHOR "(Chip L., HICTOP i3 Mendel v1.1.0-RC6)" // CL: updated info. Who made the changes.
#define SHOW_BOOTSCREEN
#define STRING_SPLASH_LINE1 SHORT_BUILD_VERSION // CL: enabled, was =disabled. will be shown during bootup in line 1
#define STRING_SPLASH_LINE2 STRING_DISTRIBUTION_DATE // CL: enabled, was =disabled. will be shown during bootup in line 2
// @section machine
// SERIAL_PORT selects which serial port should be used for communication with the host.
// This allows the connection of wireless adapters (for instance) to non-default port pins.
// Serial port 0 is still used by the Arduino bootloader regardless of this setting.
// :[0,1,2,3,4,5,6,7]
#define SERIAL_PORT 0
// This determines the communication speed of the printer
// :[2400,9600,19200,38400,57600,115200,250000]
//#define BAUDRATE 250000
#define BAUDRATE 115200 // CL: for HIC i3, was =250000
// Enable the Bluetooth serial interface on AT90USB devices
//#define BLUETOOTH
// The following define selects which electronics board you have.
// Please choose the name from boards.h that matches your setup
#ifndef MOTHERBOARD
  #define MOTHERBOARD BOARD_RAMPS_14_EFB // default board
    //#define MOTHERBOARD BOARD_RAMPS_13_EFB // CL: original in RC3 for HIC i3, RAMPS 1.3 (Power outputs: Extruder, Fan, Bed)
  #endif
// Optional custom name for your RepStrap or other custom machine
// Displayed in the LCD "Ready" message
//#define CUSTOM_MACHINE_NAME "3D Printer"
#define CUSTOM_MACHINE_NAME "HICi3 v1.1RC6" // CL: put version number on LCD menu
// Define this to set a unique identifier for this printer, (Used by some programs to differentiate between machines)
// You can use an online service to generate a random UUID. (eg http://www.uuidgenerator.net/version4)
//#define MACHINE_UUID "00000000-0000-0000-0000-000000000000"
// This defines the number of extruders
// :[1,2,3,4]
#define EXTRUDERS 1
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
//#define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
//#define EXTRUDER_OFFSET_Y {0.0, 5.00}  // (in mm) for each extruder, offset of the hotend on the Y axis
//// The following define selects which power supply you have. Please choose the one that matches your setup
// 1 = ATX
// 2 = X-Box 360 203Watts (the blue wire connected to PS_ON and the red wire to VCC)
// :{1:'ATX',2:'X-Box 360'}
#define POWER_SUPPLY 1
// Define this to have the electronics keep the power supply off on startup. If you don't know what this is leave it.
//#define PS_DEFAULT_OFF
// @section temperature
//============================= Thermal Settings ============================
//--NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table
//// Temperature sensor settings:
// -3 is thermocouple with MAX31855 (only for sensor 0)
// -2 is thermocouple with MAX6675 (only for sensor 0)
// -1 is thermocouple with AD595
// 0 is not used
// 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
// 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
// 3 is Mendel-parts thermistor (4.7k pullup)
// 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
// 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup)
// 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
// 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
// 71 is 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup)
// 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup)
// 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup)
// 10 is 100k RS thermistor 198-961 (4.7k pullup)
// 11 is 100k beta 3950 1% thermistor (4.7k pullup)
// 12 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed)
// 13 is 100k Hisens 3950  1% up to 300°C for hotend "Simple ONE " & "Hotend "All In ONE"
// 20 is the PT100 circuit found in the Ultimainboard V2.x
// 60 is 100k Maker's Tool Works Kapton Bed Thermistor beta=3950
// 70 is the 100K thermistor found in the bq Hephestos 2
//    1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k
//                          (but gives greater accuracy and more stable PID)
// 51 is 100k thermistor - EPCOS (1k pullup)
// 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
// 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup)
// 1047 is Pt1000 with 4k7 pullup
// 1010 is Pt1000 with 1k pullup (non standard)
// 147 is Pt100 with 4k7 pullup
// 110 is Pt100 with 1k pullup (non standard)
// 998 and 999 are Dummy Tables. They will ALWAYS read 25°C or the temperature defined below.
//     Use it for Testing or Development purposes. NEVER for production machine.
//#define DUMMY_THERMISTOR_998_VALUE 25
//#define DUMMY_THERMISTOR_999_VALUE 100
// :{ '0': "Not used", '4': "10k !! do not use for a hotend. Bad resolution at high temp. !!", '1': "100k / 4.7k - EPCOS", '51': "100k / 1k - EPCOS", '6': "100k / 4.7k EPCOS - Not as accurate as Table 1", '5': "100K / 4.7k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)", '7': "100k / 4.7k Honeywell 135-104LAG-J01", '71': "100k / 4.7k Honeywell 135-104LAF-J01", '8': "100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT", '9': "100k / 4.7k GE Sensing AL03006-58.2K-97-G1", '10': "100k / 4.7k RS 198-961", '11': "100k / 4.7k beta 3950 1%", '12': "100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT (calibrated for Makibox hot bed)", '13': "100k Hisens 3950  1% up to 300°C for hotend 'Simple ONE ' & hotend 'All In ONE'", '60': "100k Maker's Tool Works Kapton Bed Thermistor beta=3950", '55': "100k / 1k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)", '2': "200k / 4.7k - ATC Semitec 204GT-2", '52': "200k / 1k - ATC Semitec 204GT-2", '-3': "Thermocouple + MAX31855 (only for sensor 0)", '-2': "Thermocouple + MAX6675 (only for sensor 0)", '-1': "Thermocouple + AD595", '3': "Mendel-parts / 4.7k", '1047': "Pt1000 / 4.7k", '1010': "Pt1000 / 1k (non standard)", '20': "PT100 (Ultimainboard V2.x)", '147': "Pt100 / 4.7k", '110': "Pt100 / 1k (non-standard)", '998': "Dummy 1", '999': "Dummy 2" }
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_BED 1 // CL: for HIC i3, was =0
// This makes temp sensor 1 a redundant sensor for sensor 0. If the temperatures difference between these sensors is to high the print will be aborted.
//#define TEMP_SENSOR_1_AS_REDUNDANT
#define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10
// Extruder temperature must be close to target for this long before M109 returns success
#define TEMP_RESIDENCY_TIME 10  // (seconds)
#define TEMP_HYSTERESIS 3       // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_WINDOW     1       // (degC) Window around target to start the residency timer x degC early.
// Bed temperature must be close to target for this long before M190 returns success
#define TEMP_BED_RESIDENCY_TIME 10  // (seconds)
#define TEMP_BED_HYSTERESIS 3       // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_BED_WINDOW     1       // (degC) Window around target to start the residency timer x degC early.
// The minimal temperature defines the temperature below which the heater will not be enabled It is used
// to check that the wiring to the thermistor is not broken.
// Otherwise this would lead to the heater being powered on all the time.
#define HEATER_0_MINTEMP 5
#define HEATER_1_MINTEMP 5
#define HEATER_2_MINTEMP 5
#define HEATER_3_MINTEMP 5
#define BED_MINTEMP 5
// When temperature exceeds max temp, your heater will be switched off.
// This feature exists to protect your hotend from overheating accidentally, but *NOT* from thermistor short/failure!
// You should use MINTEMP for thermistor short/failure protection.
#define HEATER_0_MAXTEMP 270 // CL: lower for HIC i3, was =275
#define HEATER_1_MAXTEMP 270 // CL: lower for HIC i3, was =275
#define HEATER_2_MAXTEMP 270 // CL: lower for HIC i3, was =275
#define HEATER_3_MAXTEMP 270 // CL: lower for HIC i3, was =275
#define BED_MAXTEMP 160 // CL: lower for HIC i3, was =150
// If you want the M105 heater power reported in watts, define the BED_WATTS, and (shared for all extruders) EXTRUDER_WATTS
//#define EXTRUDER_WATTS (12.0*12.0/6.7) // P=U^2/R
//#define BED_WATTS (12.0*12.0/1.1)      // P=U^2/R
//============================= PID Settings ================================
// PID Tuning Guide here: http://reprap.org/wiki/PID_Tuning
// Comment the following line to disable PID and enable bang-bang.
#define PIDTEMP
#define BANG_MAX 255 // limits current to nozzle while in bang-bang mode; 255=full current
#define PID_MAX BANG_MAX // limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 255=full current
#if ENABLED(PIDTEMP)
  //#define PID_AUTOTUNE_MENU // Add PID Autotune to the LCD "Temperature" menu to run M303 and apply the result.
  //#define PID_DEBUG // Sends debug data to the serial port.
  //#define PID_OPENLOOP 1 // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX
  //#define SLOW_PWM_HEATERS // PWM with very low frequency (roughly 0.125Hz=8s) and minimum state time of approximately 1s useful for heaters driven by a relay
  //#define PID_PARAMS_PER_EXTRUDER // Uses separate PID parameters for each extruder (useful for mismatched extruders)
                                    // Set/get with gcode: M301 E[extruder number, 0-2]
  #define PID_FUNCTIONAL_RANGE 10 // If the temperature difference between the target temperature and the actual temperature
                                  // is more than PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max.
  #define PID_INTEGRAL_DRIVE_MAX PID_MAX  //limit for the integral term
  #define K1 0.95 //smoothing factor within the PID
  // If you are using a pre-configured hotend then you can use one of the value sets by uncommenting it
  // Reprap link here for PID tuning: "http://reprap.org/wiki/PID_Tuning"
  // CL: HICTOP i3 (China), post running PID tuning
  #define  DEFAULT_Kp 12.19
  #define  DEFAULT_Ki 0.50
  #define  DEFAULT_Kd 74.60
  // Ultimaker
  //#define  DEFAULT_Kp 22.2
  //#define  DEFAULT_Ki 1.08
  //#define  DEFAULT_Kd 114
  // MakerGear
  //#define  DEFAULT_Kp 7.0
  //#define  DEFAULT_Ki 0.1
  //#define  DEFAULT_Kd 12
  // Mendel Parts V9 on 12V
  //#define  DEFAULT_Kp 63.0
  //#define  DEFAULT_Ki 2.25
  //#define  DEFAULT_Kd 440
#endif // PIDTEMP
//============================= PID > Bed Temperature Control ===============
// Select PID or bang-bang with PIDTEMPBED. If bang-bang, BED_LIMIT_SWITCHING will enable hysteresis
// Uncomment this to enable PID on the bed. It uses the same frequency PWM as the extruder.
// If your PID_dT is the default, and correct for your hardware/configuration, that means 7.689Hz,
// which is fine for driving a square wave into a resistive load and does not significantly impact you FET heating.
// This also works fine on a Fotek SSR-10DA Solid State Relay into a 250W heater.
// If your configuration is significantly different than this and you don't understand the issues involved, you probably
// shouldn't use bed PID until someone else verifies your hardware works.
// If this is enabled, find your own PID constants below.
//#define PIDTEMPBED
//#define BED_LIMIT_SWITCHING
// This sets the max power delivered to the bed, and replaces the HEATER_BED_DUTY_CYCLE_DIVIDER option.
// all forms of bed control obey this (PID, bang-bang, bang-bang with hysteresis)
// setting this to anything other than 255 enables a form of PWM to the bed just like HEATER_BED_DUTY_CYCLE_DIVIDER did,
// so you shouldn't use it unless you are OK with PWM on your bed.  (see the comment on enabling PIDTEMPBED)
#define MAX_BED_POWER 255 // limits duty cycle to bed; 255=full current
#if ENABLED(PIDTEMPBED)
  //#define PID_BED_DEBUG // Sends debug data to the serial port.
  #define PID_BED_INTEGRAL_DRIVE_MAX MAX_BED_POWER //limit for the integral term
  //120V 250W silicone heater into 4mm borosilicate (MendelMax 1.5+)
  //from FOPDT model - kp=.39 Tp=405 Tdead=66, Tc set to 79.2, aggressive factor of .15 (vs .1, 1, 10)
  #define  DEFAULT_bedKp 10.00
  #define  DEFAULT_bedKi .023
  #define  DEFAULT_bedKd 305.4
  //from pidautotune
  //#define  DEFAULT_bedKp 97.1
  //#define  DEFAULT_bedKi 1.41
  //#define  DEFAULT_bedKd 1675.16
  // FIND YOUR OWN: "M303 E-1 C8 S90" to run autotune on the bed at 90 degreesC for 8 cycles.
#endif // PIDTEMPBED
// @section extruder
//this prevents dangerous Extruder moves, i.e. if the temperature is under the limit
//can be software-disabled for whatever purposes by
#define PREVENT_DANGEROUS_EXTRUDE
//if PREVENT_DANGEROUS_EXTRUDE is on, you can still disable (uncomment) very long bits of extrusion separately.
#define PREVENT_LENGTHY_EXTRUDE
#define EXTRUDE_MINTEMP 170
#define EXTRUDE_MAXLENGTH (X_MAX_LENGTH+Y_MAX_LENGTH) //prevent extrusion of very large distances.
//======================== Thermal Runaway Protection =======================
 * Thermal Protection protects your printer from damage and fire if a
 * thermistor falls out or temperature sensors fail in any way.
 * The issue: If a thermistor falls out or a temperature sensor fails,
 * Marlin can no longer sense the actual temperature. Since a disconnected
 * thermistor reads as a low temperature, the firmware will keep the heater on.
 * If you get "Thermal Runaway" or "Heating failed" errors the
 * details can be tuned in Configuration_adv.h
#define THERMAL_PROTECTION_HOTENDS // Enable thermal protection for all extruders
#define THERMAL_PROTECTION_BED     // Enable thermal protection for the heated bed
//============================= Mechanical Settings =========================
// @section machine
// Uncomment this option to enable CoreXY kinematics
//#define COREXY
// Uncomment this option to enable CoreXZ kinematics
//#define COREXZ
// Enable this option for Toshiba steppers
//#define CONFIG_STEPPERS_TOSHIBA
//============================== Endstop Settings ===========================
// @section homing
// Specify here all the endstop connectors that are connected to any endstop or probe.
// Almost all printers will be using one per axis. Probes will use one or more of the
// extra connectors. Leave undefined any used for non-endstop and non-probe purposes.
#define USE_XMIN_PLUG
#define USE_YMIN_PLUG
#define USE_ZMIN_PLUG
//#define USE_XMAX_PLUG
//#define USE_YMAX_PLUG
//#define USE_ZMAX_PLUG
// coarse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#if DISABLED(ENDSTOPPULLUPS)
  // fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined
  //#define ENDSTOPPULLUP_XMAX
  //#define ENDSTOPPULLUP_YMAX
  //#define ENDSTOPPULLUP_ZMAX
  //#define ENDSTOPPULLUP_XMIN
  //#define ENDSTOPPULLUP_YMIN
  //#define ENDSTOPPULLUP_ZMIN
  #define ENDSTOPPULLUP_ZMIN_PROBE
#endif
// Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup).
// CL: set all to =true for HIC i3, was all =false NOTE: need to upgrade to NC to ground switches!
const bool X_MIN_ENDSTOP_INVERTING = true; // CL: set to true to invert the logic of the endstop. was =false
const bool Y_MIN_ENDSTOP_INVERTING = true; // CL: set to true to invert the logic of the endstop. was =false
const bool Z_MIN_ENDSTOP_INVERTING = true; // CL: set to true to invert the logic of the endstop. was =false
const bool X_MAX_ENDSTOP_INVERTING = true; // CL: set to true to invert the logic of the endstop. was =false
const bool Y_MAX_ENDSTOP_INVERTING = true; // CL: set to true to invert the logic of the endstop. was =false
const bool Z_MAX_ENDSTOP_INVERTING = true; // CL: set to true to invert the logic of the endstop. was =false
const bool Z_MIN_PROBE_ENDSTOP_INVERTING = true; // CL: set to true to invert the logic of the endstop. was =false
//============================= Z Probe Options =============================
// Enable Z_MIN_PROBE_ENDSTOP to use _both_ a Z Probe and a Z-min-endstop on the same machine.
// With this option the Z_MIN_PROBE_PIN will only be used for probing, never for homing.
// *** PLEASE READ ALL INSTRUCTIONS BELOW FOR SAFETY! ***
// To continue using the Z-min-endstop for homing, be sure to disable Z_SAFE_HOMING.
// Example: To park the head outside the bed area when homing with G28.
// To use a separate Z probe, your board must define a Z_MIN_PROBE_PIN.
// For a servo-based Z probe, you must set up servo support below, including
// NUM_SERVOS, Z_ENDSTOP_SERVO_NR and SERVO_ENDSTOP_ANGLES.
// - RAMPS 1.3/1.4 boards may be able to use the 5V, GND, and Aux4->D32 pin.
// - Use 5V for powered (usu. inductive) sensors.
// - Otherwise connect:
//   - normally-closed switches to GND and D32.
//   - normally-open switches to 5V and D32.
// Normally-closed switches are advised and are the default.
// The Z_MIN_PROBE_PIN sets the Arduino pin to use. (See your board's pins file.)
// Since the RAMPS Aux4->D32 pin maps directly to the Arduino D32 pin, D32 is the
// default pin for all RAMPS-based boards. Some other boards map differently.
// To set or change the pin for your board, edit the appropriate pins_XXXXX.h file.
// WARNING:
// Setting the wrong pin may have unexpected and potentially disastrous consequences.
// Use with caution and do your homework.
//#define Z_MIN_PROBE_ENDSTOP
// Enable Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN to use the Z_MIN_PIN for your Z_MIN_PROBE.
// The Z_MIN_PIN will then be used for both Z-homing and probing.
#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
// To use a probe you must enable one of the two options above!
// This option disables the use of the Z_MIN_PROBE_PIN
// To enable the Z probe pin but disable its use, uncomment the line below. This only affects a
// Z probe switch if you have a separate Z min endstop also and have activated Z_MIN_PROBE_ENDSTOP above.
// If you're using the Z MIN endstop connector for your Z probe, this has no effect.
//#define DISABLE_Z_MIN_PROBE_ENDSTOP
// For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1
// :{0:'Low',1:'High'}
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis stepper immediately when it's not being used.
// WARNING: When motors turn off there is a chance of losing position accuracy!
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
// Warn on display about possibly reduced accuracy
//#define DISABLE_REDUCED_ACCURACY_WARNING
#define DISABLE_E false // For all extruders
#define DISABLE_INACTIVE_EXTRUDER true //disable only inactive extruders and keep active extruder enabled
// @section machine
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way.
#define INVERT_X_DIR false
#define INVERT_Y_DIR false // CL: for HICi3 =false, was =true
#define INVERT_Z_DIR true // CL: for HICi3 =true, was =fals
// For direct drive extruder v9 set to true, for geared extruder set to false.
#define INVERT_E0_DIR false
#define INVERT_E1_DIR false
#define INVERT_E2_DIR false
#define INVERT_E3_DIR false
// @section homing
//#define MIN_Z_HEIGHT_FOR_HOMING 4 // (in mm) Minimal z height before homing (G28) for Z clearance above the bed, clamps, ...
                                    // Be sure you have this distance over your Z_MAX_POS in case.
// ENDSTOP SETTINGS:
// Sets direction of endstops when homing; 1=MAX, -1=MIN
// :[-1,1]
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true  // If true, axis won't move to coordinates greater than the defined lengths below.
// @section machine
// Travel limits after homing (units are in mm)
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define X_MAX_POS 220 //CL HIC i3 actual X bed size 220mm, was =205
#define Y_MAX_POS 270 //CL HIC i3 actual Y bed size 270mm, was =205
#define Z_MAX_POS 185 //CL HIC i3 actual Z height measured = 185mm, set this for your actual Z height, was =200
//========================= Filament Runout Sensor ==========================
#define FILAMENT_RUNOUT_SENSOR // Uncomment for defining a filament runout sensor such as a mechanical or opto endstop to check the existence of filament
                                 // In RAMPS uses servo pin 2. Can be changed in pins file. For other boards pin definition should be made.
                                 // It is assumed that when logic high = filament available
                                 //                    when logic  low = filament ran out
#if ENABLED(FILAMENT_RUNOUT_SENSOR)
  const bool FIL_RUNOUT_INVERTING = true;  // Should be uncommented and true or false should assigned
  #define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined.
  #define FILAMENT_RUNOUT_SCRIPT "M600"
#endif
//============================ Mesh Bed Leveling ============================
//#define MESH_BED_LEVELING    // Enable mesh bed leveling.
#if ENABLED(MESH_BED_LEVELING)
  #define MESH_MIN_X 10
  #define MESH_MAX_X (X_MAX_POS - (MESH_MIN_X))
  #define MESH_MIN_Y 10
  #define MESH_MAX_Y (Y_MAX_POS - (MESH_MIN_Y))
  #define MESH_NUM_X_POINTS 3  // Don't use more than 7 points per axis, implementation limited.
  #define MESH_NUM_Y_POINTS 3
  #define MESH_HOME_SEARCH_Z 4  // Z after Home, bed somewhere below but above 0.0.
  //#define MANUAL_BED_LEVELING  // Add display menu option for bed leveling.
  #if ENABLED(MANUAL_BED_LEVELING)
    #define MBL_Z_STEP 0.025  // Step size while manually probing Z axis.
  #endif  // MANUAL_BED_LEVELING
#endif  // MESH_BED_LEVELING
//============================ Bed Auto Leveling ============================
// @section bedlevel
#define AUTO_BED_LEVELING_FEATURE // Delete the comment to enable (remove // at the start of the line)
#define DEBUG_LEVELING_FEATURE
#define Z_MIN_PROBE_REPEATABILITY_TEST  // If not commented out, Z Probe Repeatability test will be included if Auto Bed Leveling is Enabled.
#if ENABLED(AUTO_BED_LEVELING_FEATURE)
  // There are 2 different ways to specify probing locations:
  // - "grid" mode
  //   Probe several points in a rectangular grid.
  //   You specify the rectangle and the density of sample points.
  //   This mode is preferred because there are more measurements.
  // - "3-point" mode
  //   Probe 3 arbitrary points on the bed (that aren't collinear)
  //   You specify the XY coordinates of all 3 points.
  // Enable this to sample the bed in a grid (least squares solution).
  // Note: this feature generates 10KB extra code size.
  #define AUTO_BED_LEVELING_GRID
  #if ENABLED(AUTO_BED_LEVELING_GRID)
    #define LEFT_PROBE_BED_POSITION 15
    #define RIGHT_PROBE_BED_POSITION 170
    #define FRONT_PROBE_BED_POSITION 20
    #define BACK_PROBE_BED_POSITION 170
    #define MIN_PROBE_EDGE 10 // The Z probe minimum square sides can be no smaller than this.
    // Set the number of grid points per dimension.
    // You probably don't need more than 3 (squared=9).
    #define AUTO_BED_LEVELING_GRID_POINTS 3
  #else  // !AUTO_BED_LEVELING_GRID
    // Arbitrary points to probe.
    // A simple cross-product is used to estimate the plane of the bed.
    #define ABL_PROBE_PT_1_X 15
    #define ABL_PROBE_PT_1_Y 200
    #define ABL_PROBE_PT_2_X 15
    #define ABL_PROBE_PT_2_Y 20
    #define ABL_PROBE_PT_3_X 190
    #define ABL_PROBE_PT_3_Y 20
  #endif // AUTO_BED_LEVELING_GRID
  // Z Probe to nozzle (X,Y) offset, relative to (0, 0).
  // X and Y offsets must be integers.
  // In the following example the X and Y offsets are both positive:
  // #define X_PROBE_OFFSET_FROM_EXTRUDER 10
  // #define Y_PROBE_OFFSET_FROM_EXTRUDER 10
  //    +-- BACK ---+
  //  L |    (+) P  | R <-- probe (20,20)
  //  E |           | I
  //  F | (-) N (+) | G <-- nozzle (10,10)
  //  T |           | H
  //    |    (-)    | T
  //    O-- FRONT --+
  //  (0,0)
  #define X_PROBE_OFFSET_FROM_EXTRUDER 10  // X offset: -left  +right  [of the nozzle]
  #define Y_PROBE_OFFSET_FROM_EXTRUDER 10  // Y offset: -front +behind [the nozzle]
  #define Z_PROBE_OFFSET_FROM_EXTRUDER -1   // Z offset: -below +above  [the nozzle]
  #define XY_TRAVEL_SPEED 12000         // X and Y axis travel speed between probes, in mm/min.
  #define Z_RAISE_BEFORE_PROBING 10   // How much the Z axis will be raised before traveling to the first probing point.
  #define Z_RAISE_BETWEEN_PROBINGS 5  // How much the Z axis will be raised when traveling from between next probing points.
  #define Z_RAISE_AFTER_PROBING 15    // How much the Z axis will be raised after the last probing point.
  #define Z_PROBE_END_SCRIPT "G1 X10 Y10 Z15" // These commands will be executed in the end of G29 routine.
        // Useful to retract a deployable Z probe.
  // Probes are sensors/switches that need to be activated before they can be used
  // and deactivated after their use.
  // Allen Key Probes, Servo Probes, Z-Sled Probes, FIX_MOUNTED_PROBE, ... . You have to activate one of these for the AUTO_BED_LEVELING_FEATURE
  // A fix mounted probe, like the normal inductive probe, must be deactivated to go below Z_PROBE_OFFSET_FROM_EXTRUDER
  // when the hardware endstops are active.
  #define FIX_MOUNTED_PROBE
  // A Servo Probe can be defined in the servo section below.
  // An Allen Key Probe is currently predefined only in the delta example configurations.
  // Enable if you have a Z probe mounted on a sled like those designed by Charles Bell.
  //#define Z_PROBE_SLED
  //#define SLED_DOCKING_OFFSET 5 // The extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like.
  // A Mechanical Probe is any probe that either doesn't deploy or needs manual deployment
  // For example any setup that uses the nozzle itself as a probe.
  //#define MECHANICAL_PROBE
  // If you've enabled AUTO_BED_LEVELING_FEATURE and are using the Z Probe for Z Homing,
  // it is highly recommended you also enable Z_SAFE_HOMING below!
#endif // AUTO_BED_LEVELING_FEATURE
// @section homing
// The position of the homing switches
//#define MANUAL_HOME_POSITIONS  // If defined, MANUAL_*_HOME_POS below will be used
//#define BED_CENTER_AT_0_0  // If defined, the center of the bed is at (X=0, Y=0)
// Manual homing switch locations:
// For deltabots this means top and center of the Cartesian print volume.
#if ENABLED(MANUAL_HOME_POSITIONS)
  #define MANUAL_X_HOME_POS 0
  #define MANUAL_Y_HOME_POS 0
  #define MANUAL_Z_HOME_POS 0
  //#define MANUAL_Z_HOME_POS 402 // For delta: Distance between nozzle and print surface after homing.
#endif
// Use "Z Safe Homing" to avoid homing with a Z probe outside the bed area.
// With this feature enabled:
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled.
// - If stepper drivers time out, it will need X and Y homing again before Z homing.
// - Position the Z probe in a defined XY point before Z Homing when homing all axes (G28).
// - Prevent Z homing when the Z probe is outside bed area.
#define Z_SAFE_HOMING
#if ENABLED(Z_SAFE_HOMING)
  #define Z_SAFE_HOMING_X_POINT ((X_MIN_POS + X_MAX_POS) / 2)    // X point for Z homing when homing all axis (G28).
  #define Z_SAFE_HOMING_Y_POINT ((Y_MIN_POS + Y_MAX_POS) / 2)    // Y point for Z homing when homing all axis (G28).
#endif
// @section movement
 * MOVEMENT SETTINGS
#define HOMING_FEEDRATE {50*60, 50*60, 4*60, 0}  // set the homing speeds (mm/min)
// Default AXIS STEPS, MAX_FEEDRATE, ACCLERATION settings
// Default AXIS STEP Settings (motor steps) X, Y, Z, E
// 1a) default axis steps per unit for Ultimaker steps/mm ={8.7402,78.7402,200.0*8/3,760*1.1}
// 1b) default axis steps per unit for HIC i3 steps/mm ={80,80,2560,94.4962144}, OEM z-axis threaded rods =8mm wide x 1.25mm pitch
//#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,2560,94.4962144} // original default for HIC i3, (steps/mm)
#define DEFAULT_AXIS_STEPS_PER_UNIT {80, 80, 2559, 102} // CL: default steps for  _my_ HIC i3, you may need to change the Z and/or E for your machine
// Default MAXIMUM FEEDRATES (motor speeds) X, Y, Z, E - GLOBAL for printing and non-printing
//#define DEFAULT_MAX_FEEDRATE {200, 200, 5, 17} // (mm/sec) default for Makerbot i3
//#define DEFAULT_MAX_FEEDRATE {300, 300, 5, 25} // (mm/sec) default for Marlin
//#define DEFAULT_MAX_FEEDRATE {500, 500, 5, 25} // (mm/sec) original default for HIC i3
#define DEFAULT_MAX_FEEDRATE {200, 200, 3, 25} // (mm/sec) CL: default HIC i3
// Default MAXIMUM ACCELERATION (motor) X, Y, Z, E=(extrusion only) - max start speeds for accelrated moves
// NOTE: value stored in DEFAULT_ACCELERATION if lower, will limit these MAX rates
//#define DEFAULT_MAX_ACCELERATION {3000,3000,100,10000} // (mm/sec^2) Marlin default - X, Y, Z, E(moves) maximum start speed for accelerated moves
//#define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000} // (mm/sec^2) original default for HIC i3 - X, Y, Z, E(moves) maximum start speed for accelerated moves
#define DEFAULT_MAX_ACCELERATION {1000, 1000, 100, 10000} // (mm/sec^2) CL: default for HIC i3 - X, Y, Z, E(moves) maximum start speed for accelerated moves
// E default values are good for Skeinforge 40+, for older versions raise them a lot.
// Default misc. ACCELERATIONS
//#define DEFAULT_ACCELERATION 500 // (mm/sec^2) default for Makerbot i3 - X, Y, Z and E max acceleration for printing moves
#define DEFAULT_ACCELERATION          3000 // (mm/sec^2) CL: default for HIC i3 - X, Y, Z and E max acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION  3000 // (mm/sec^2) CL: default for HIC i3 E acceleration for retracts (fliament purge and feed)
#define DEFAULT_TRAVEL_ACCELERATION   3000 // (mm/sec^2) CL: default for HIC i3 X, Y, Z acceleration for travel (non-printing) moves
// The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously)
// default jerk values for HIC i3 ={20.0, 0.4, 5.0} (mm/sec)
#define DEFAULT_XYJERK                10.0 // (mm/sec) CL: new default for HIC i3, was =20
#define DEFAULT_ZJERK                 0.3  // (mm/sec)
#define DEFAULT_EJERK                 3.0  // (mm/sec)
//============================= Additional Features ===========================
// @section more
// Custom M code points
#define CUSTOM_M_CODES
#if ENABLED(CUSTOM_M_CODES)
    #define CUSTOM_M_CODE_SET_Z_PROBE_OFFSET 851
    #define Z_PROBE_OFFSET_RANGE_MIN -20
    #define Z_PROBE_OFFSET_RANGE_MAX 20
  #endif
#endif
// @section extras
// EEPROM
// The microcontroller can store settings in the EEPROM, e.g. max velocity...
// M500 - stores parameters in EEPROM
// M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
// M502 - reverts to the default "factory settings".  You still need to store them in EEPROM afterwards if you want to.
//define this to enable EEPROM support
#define EEPROM_SETTINGS
#if ENABLED(EEPROM_SETTINGS)
  // To disable EEPROM Serial responses and decrease program space by ~1700 byte: comment this out:
  #define EEPROM_CHITCHAT // Please keep turned on if you can.
#endif
// Host Keepalive
// By default Marlin will send a busy status message to the host
// every couple of seconds when it can't accept commands.
//#define DISABLE_HOST_KEEPALIVE // Enable this option if your host doesn't like keepalive messages.
#if DISABLED(DISABLE_HOST_KEEPALIVE)
  #define DEFAULT_KEEPALIVE_INTERVAL 2 // Number of seconds between "busy" messages. Set with M113.
#endif
// M100 Free Memory Watcher
#define M100_FREE_MEMORY_WATCHER // uncomment to add the M100 Free Memory Watcher for debug purpose
// Preheat Constants
#define PLA_PREHEAT_HOTEND_TEMP 205 // CL: too low for current PLA, was=180
#define PLA_PREHEAT_HPB_TEMP 60 // CL: too high for current PLA, was=70
#define PLA_PREHEAT_FAN_SPEED 0 // Insert Value between 0 and 255
#define ABS_PREHEAT_HOTEND_TEMP 240
#define ABS_PREHEAT_HPB_TEMP 100 // CL: lowered for HICi3, was =110
#define ABS_PREHEAT_FAN_SPEED 0 // Insert Value between 0 and 255
//============================= LCD and SD support ============================
// @section lcd
// LCD LANGUAGE
// Here you may choose the language used by Marlin on the LCD menus, the following
// list of languages are available:
//    en, pl, fr, de, es, ru, bg, it, pt, pt_utf8, pt-br, pt-br_utf8,
//    fi, an, nl, ca, eu, kana, kana_utf8, cn, cz, test
#define LANGUAGE_INCLUDE GENERATE_LANGUAGE_INCLUDE(en)
// LCD CHARACTER SET
// Choose ONE of the following charset options. This selection depends on
// your physical hardware, so it must match your character-based LCD.
// Note: This option is NOT applicable to graphical displays.
// To find out what type of display you have:
//  - Compile and upload with the language (above) set to 'test'
//  - Click the controller to view the LCD menu
// The LCD will display two lines from the upper half of the character set.
// See also https://github.com/MarlinFirmware/Marlin/wiki/LCD-Language
#define DISPLAY_CHARSET_HD44780_JAPAN        // this is the most common hardware
//#define DISPLAY_CHARSET_HD44780_WESTERN
//#define DISPLAY_CHARSET_HD44780_CYRILLIC
// LCD TYPE
// You may choose ULTRA_LCD if you have character based LCD with 16x2, 16x4, 20x2,
// 20x4 char/lines or DOGLCD for the full graphics display with 128x64 pixels
// (ST7565R family). (This option will be set automatically for certain displays.)
// IMPORTANT NOTE: The U8glib library is required for Full Graphic Display!
//                 https://github.com/olikraus/U8glib_Arduino
//#define ULTRA_LCD   // Character based
//#define DOGLCD      // Full graphics display
// SD CARD
// SD Card support is disabled by default. If your controller has an SD slot,
// you must uncomment the following option or it won't work.
#define SDSUPPORT // CL: HICi3 LCD panel, was =not enabled
// SD CARD: SPI SPEED
// Uncomment ONE of the following items to use a slower SPI transfer
// speed. This is usually required if you're getting volume init errors.
#define SPI_SPEED SPI_HALF_SPEED // (CL: HICi3 LCD panel (TEST), was =not enabled
//#define SPI_SPEED SPI_QUARTER_SPEED
//#define SPI_SPEED SPI_EIGHTH_SPEED
// SD CARD: ENABLE CRC
// Use CRC checks and retries on the SD communication.
#define SD_CHECK_AND_RETRY // (CL: HICi3 LCD panel (TEST), was =not enabled
// ENCODER SETTINGS
// This option overrides the default number of encoder pulses needed to
// produce one step. Should be increased for high-resolution encoders.
#define ENCODER_PULSES_PER_STEP 4 // CL: HICi3 =4, was =1
// Use this option to override the number of step signals required to
// move between next/prev menu items.
#define ENCODER_STEPS_PER_MENU_ITEM 1 // CL: HICi3 =1, was =5, Set according to ENCODER_PULSES_PER_STEP or your liking
// This option reverses the encoder direction for navigating LCD menus.
// By default CLOCKWISE == DOWN. With this enabled CLOCKWISE == UP.
//#define REVERSE_MENU_DIRECTION
// SPEAKER/BUZZER
// If you have a speaker that can produce tones, enable it here.
// By default Marlin assumes you have a buzzer with a fixed frequency.
#define SPEAKER
// The duration and frequency for the UI feedback sound.
// Set these to 0 to disable audio feedback in the LCD menus.
// Note: Test audio output with the G-Code:
//  M300 S<frequency Hz> P<duration ms>
#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100
#define LCD_FEEDBACK_FREQUENCY_HZ 1000
// CONTROLLER TYPE: Standard
// Marlin supports a wide variety of controllers.
// Enable one of the following options to specify your controller.
// ULTIMAKER Controller.
//#define ULTIMAKERCONTROLLER
// ULTIPANEL as seen on Thingiverse.
//#define ULTIPANEL
// PanelOne from T3P3 (via RAMPS 1.4 AUX2/AUX3)
// http://reprap.org/wiki/PanelOne
//#define PANEL_ONE
// MaKr3d Makr-Panel with graphic controller and SD support.
// http://reprap.org/wiki/MaKr3d_MaKrPanel
//#define MAKRPANEL
// Activate one of these if you have a Panucatt Devices
// Viki 2.0 or mini Viki with Graphic LCD
// http://panucatt.com
//#define VIKI2
//#define miniVIKI
// Adafruit ST7565 Full Graphic Controller.
// https://github.com/eboston/Adafruit-ST7565-Full-Graphic-Controller/
//#define ELB_FULL_GRAPHIC_CONTROLLER
// RepRapDiscount Smart Controller.
// http://reprap.org/wiki/RepRapDiscount_Smart_Controller
// Note: Usually sold with a white PCB.
#define REPRAP_DISCOUNT_SMART_CONTROLLER // CL: Hici3 LCD default 20x4 Controller/Display, was =not enabled
// BQ LCD Smart Controller shipped by
// default with the BQ Hephestos 2 and Witbox 2.
//#define BQ_LCD_SMART_CONTROLLER
// GADGETS3D G3D LCD/SD Controller
// http://reprap.org/wiki/RAMPS_1.3/1.4_GADGETS3D_Shield_with_Panel
// Note: Usually sold with a blue PCB.
//#define G3D_PANEL
// RepRapDiscount FULL GRAPHIC Smart Controller
// http://reprap.org/wiki/RepRapDiscount_Full_Graphic_Smart_Controller
//#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
// MakerLab Mini Panel with graphic
// controller and SD support - http://reprap.org/wiki/Mini_panel
//#define MINIPANEL
// RepRapWorld REPRAPWORLD_KEYPAD v1.1
// http://reprapworld.com/?products_details&products_id=202&cPath=1591_1626
// REPRAPWORLD_KEYPAD_MOVE_STEP sets how much should the robot move when a key
// is pressed, a value of 10.0 means 10mm per click.
//#define REPRAPWORLD_KEYPAD
//#define REPRAPWORLD_KEYPAD_MOVE_STEP 10.0
// RigidBot Panel V1.0
// http://www.inventapart.com/
//#define RIGIDBOT_PANEL
// CONTROLLER TYPE: I2C
// Note: These controllers require the installation of Arduino's LiquidCrystal_I2C
// library. For more info: https://github.com/kiyoshigawa/LiquidCrystal_I2C
// Elefu RA Board Control Panel
// http://www.elefu.com/index.php?route=product/product&product_id=53
//#define RA_CONTROL_PANEL
// Sainsmart YW Robot (LCM1602) LCD Display
//#define LCD_I2C_SAINSMART_YWROBOT
// Generic LCM1602 LCD adapter
//#define LCM1602
// PANELOLU2 LCD with status LEDs,
// separate encoder and click inputs.
// Note: This controller requires Arduino's LiquidTWI2 library v1.2.3 or later.
// For more info: https://github.com/lincomatic/LiquidTWI2
// Note: The PANELOLU2 encoder click input can either be directly connected to
// a pin (if BTN_ENC defined to != -1) or read through I2C (when BTN_ENC == -1).
//#define LCD_I2C_PANELOLU2
// Panucatt VIKI LCD with status LEDs,
// integrated click & L/R/U/D buttons, separate encoder inputs.
//#define LCD_I2C_VIKI
// SSD1306 OLED full graphics generic display
//#define U8GLIB_SSD1306
// CONTROLLER TYPE: Shift register panels
// 2 wire Non-latching LCD SR from https://goo.gl/aJJ4sH
// LCD configuration: http://reprap.org/wiki/SAV_3D_LCD
//#define SAV_3DLCD
//=============================== Extra Features ==============================
// @section extras
// Increase the FAN PWM frequency. Removes the PWM noise but increases heating in the FET/Arduino
//#define FAST_PWM_FAN
// Use software PWM to drive the fan, as for the heaters. This uses a very low frequency
// which is not as annoying as with the hardware PWM. On the other hand, if this frequency
// is too low, you should also increment SOFT_PWM_SCALE.
//#define FAN_SOFT_PWM
// Incrementing this by 1 will double the software PWM frequency,
// affecting heaters, and the fan if FAN_SOFT_PWM is enabled.
// However, control resolution will be halved for each increment;
// at zero value, there are 128 effective control positions.
#define SOFT_PWM_SCALE 0
// Temperature status LEDs that display the hotend and bet temperature.
// If all hotends and bed temperature and temperature setpoint are < 54C then the BLUE led is on.
// Otherwise the RED led is on. There is 1C hysteresis.
//#define TEMP_STAT_LEDS
// M240  Triggers a camera by emulating a Canon RC-1 Remote
// Data from: http://www.doc-diy.net/photo/rc-1_hacked/
//#define PHOTOGRAPH_PIN     23
// SkeinForge sends the wrong arc g-codes when using Arc Point as fillet procedure
//#define SF_ARC_FIX
// Support for the BariCUDA Paste Extruder.
//#define BARICUDA
//define BlinkM/CyzRgb Support
//#define BLINKM
* R/C SERVO support
* Sponsored by TrinityLabs, Reworked by codexmas
// Number of servos
// If you select a configuration below, this will receive a default value and does not need to be set manually
// set it manually if you have more servos than extruders and wish to manually control some
// leaving it undefined or defining as 0 will disable the servo subsystem
// If unsure, leave commented / disabled
//#define NUM_SERVOS 3 // Servo index starts with 0 for M280 command
// Servo Endstops
// This allows for servo actuated endstops, primary usage is for the Z Axis to eliminate calibration or bed height changes.
// Use M851 to set the Z probe vertical offset from the nozzle. Store that setting with M500.
//#define X_ENDSTOP_SERVO_NR 1
//#define Y_ENDSTOP_SERVO_NR 2
//#define Z_ENDSTOP_SERVO_NR 0
//#define SERVO_ENDSTOP_ANGLES {{0,0}, {0,0}, {70,0}} // X,Y,Z Axis Extend and Retract angles
// Servo deactivation
// With this option servos are powered only during movement, then turned off to prevent jitter.
//#define DEACTIVATE_SERVOS_AFTER_MOVE
#if ENABLED(DEACTIVATE_SERVOS_AFTER_MOVE)
  // Delay (in microseconds) before turning the servo off. This depends on the servo speed.
  // 300ms is a good value but you can try less delay.
  // If the servo can't reach the requested position, increase it.
  #define SERVO_DEACTIVATION_DELAY 300
#endif
 * Support for a filament diameter sensor
 * Also allows adjustment of diameter at print time (vs  at slicing)
 * Single extruder only at this point (extruder 0)
 * Motherboards
 * 34 - RAMPS1.4 - uses Analog input 5 on the AUX2 connector
 * 81 - Printrboard - Uses Analog input 2 on the Exp1 connector (version B,C,D,E)
 * 301 - Rambo  - uses Analog input 3
 * Note may require analog pins to be defined for different motherboards
// Uncomment below to enable
//#define FILAMENT_WIDTH_SENSOR
#define DEFAULT_NOMINAL_FILAMENT_DIA 1.75  //Enter the diameter (in mm) of the filament generally used (3.0 mm or 1.75 mm) - this is then used in the slicer software.  Used for sensor reading validation
#if ENABLED(FILAMENT_WIDTH_SENSOR)
  #define FILAMENT_SENSOR_EXTRUDER_NUM 0   //The number of the extruder that has the filament sensor (0,1,2)
  #define MEASUREMENT_DELAY_CM        14   //measurement delay in cm.  This is the distance from filament sensor to middle of barrel
  #define MEASURED_UPPER_LIMIT         3.30  //upper limit factor used for sensor reading validation in mm
  #define MEASURED_LOWER_LIMIT         1.90  //lower limit factor for sensor reading validation in mm
  #define MAX_MEASUREMENT_DELAY       20     //delay buffer size in bytes (1 byte = 1cm)- limits maximum measurement delay allowable (must be larger than MEASUREMENT_DELAY_CM  and lower number saves RAM)
  #define DEFAULT_MEASURED_FILAMENT_DIA  DEFAULT_NOMINAL_FILAMENT_DIA  //set measured to nominal initially
  //When using an LCD, uncomment the line below to display the Filament sensor data on the last line instead of status.  Status will appear for 5 sec.
  //#define FILAMENT_LCD_DISPLAY
#endif
#include "Configuration_adv.h"
#include "thermistortables.h"
#endif //CONFIGURATION_H
rcabor
Re: printer totally a mess and i cant seem to sort it
Post by rcabor » February 20th, 2017, 9:02 am
Your steps are probably off.
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,398.269957,94.4962144}
This is what my Hictop uses
hoeser
3D Printer(s): i3
Post by hoeser » February 20th, 2017, 9:55 am
Most of the posted alternate firmware for the Hictop use the Z values from the old 8mm leadscrew configuration, newer hictops have proper leadscrews. The value for the newer leadscrews is about 1/8th of what's in there for the old metric 8 pitch leadscrews.
rcabor is correct - try moving default steps for Z to a value near 398.
Chaco
Post by Chaco » March 7th, 2017, 7:20 pm
why 398?
i made my calculations and came to the number of 400 and my prints are perfectly beautiful on Z
i have 8mm leadscrews with 4start 2mm pitch which is 8mm travel per rotation....
ric0
3D Printer(s): Hictop 3DP-17
Post by ric0 » March 8th, 2017, 4:14 am
Hictop Firmware sets 398 for leadscrew printers afaik, name of Hictop firmware supplied with leadscrew printers Marlin_3DP??_398.cpp and it's a lot closer than 2560 which dmkmedia has in his firmware posted above. Using 398 myself and more than satisfied with z action and print quality. But may try 400 just for the heck of it.
Chaco
Post by Chaco » March 8th, 2017, 6:36 pm
give it a shot for sure, when u use the leadscrew calculator online, you can validate...just make sure it does say the 8mm pitch our leadscrews have
