changing bed size to 12" x 12"
- 3D Printer(s): hictop aluminum
I got a Hictop aluminum extruded printer and bough some rods and extrusion so that I can chage bed to 12"x12", I am using a pice of pirex for the larger print bed, and have glued it to the hot bed. I changed the size in cura, but the print is cut off. I need to edit the firmware. I have gotten the Marlin_3DP08_3DP11_398.cpp.hex from hictop. what do i need to get it to work.
