Changing nozzles and shell thickness
Post by LePaul » March 17th, 2016, 2:15 pm
Toying around in Cura, I noticed when I changed the nozzle size (Under Advanced) to 0.6, the Shell Thickness turned yellow, indicating that should be changed.
It didn't offer me a tip/solution on what should be used as it does in most areas when hovered over
I have some large prints to do in the future and curious if a 0.6 mm nozzle is suitable for 0.2 layer height prints?
Re: Changing nozzles and shell thickness
Post by reibuehl » March 17th, 2016, 2:43 pm
I assume you had a shell thickness set that is not a multiple of 0.6 mm. The outer shell (that is not the layer height) has to be a multiple of the nozzle diameter, e.g. Shell 0.6 equals 1 line with the 0.6 nozzle, 1.2 equals 2 lines per layer as outside. A outside shell thickness of 0.8 however can not be printed as the printer can't print 1,5 lines :-)
Reiner.
Post by LePaul » March 18th, 2016, 11:20 am
Okay, that's helpful. I wasn't sure what the math was
