Alternate Display versions
Posted: November 25th, 2016, 4:31 pm
by Izzy
Does anybody have links to alternative display layouts for the UM2?
I remember some time back on the UM forum, there were alternative versions with different icons and information on the display but I can't locate them anymore.
Cheers, Izzy
Re: Alternate Display versions
Posted: November 26th, 2016, 6:42 am
by reibuehl
The firmware from Tinkergnome has a very nice layout. I use that one since a while and I think it is more informative. You can also use it with two extruders.
Posted: November 26th, 2016, 7:37 am
by Izzy
Cheers reibuehl, do you have and photos of the screen shots?
And is it easy to install to swap back to the origional if you don't like it, and what about the Bondtech install?
Cheers, Izzy
Posted: November 26th, 2016, 8:13 am
by PeggyB
the nice thing it that it can show you the advanced view (tinkergnome) or the original view, so you get both ways!
Posted: November 26th, 2016, 11:38 am
by reibuehl
Here is a screenshot just after starting a print:
Posted: November 26th, 2016, 3:29 pm
by Izzy
Oh ok so you are able to flit between the two displays, what about the Bontech feeder firmware is it still ok to use it or does it require an additional install?
Posted: November 26th, 2016, 4:01 pm
Bontech just changes the esteps. With tinkergnome you can do that manually with the menu. Or using the gcode file that bondtech has on their website. Is just a small program gcde that changes the esteps and saves that new value on the firmware.
