PEI Question
mikeamick
3D Printer(s): tevo tarantula
PEI Question
Post by mikeamick » July 6th, 2019, 1:30 am
Thought I would try some PEI. Bought a sheet and applied it to glass.
Directions said to preheat the bed to anywhere between 60 and 100 to smooth
it out. (Seemed like an unnecessary step)
I heated it to 75 and it bubbled. I mean big bubbles like 1/2 in bubbles.
I was planning on using it for higher than PLA temps, but doesn't look like it's going to work.
Re: PEI Question
Post by LePaul » July 6th, 2019, 12:14 pm
Make sure that's not the protective coating!
I applied some PEI I bought from a vendor and got bubbles...and he asked if I had removed the top/protective coating!
mikeamick
Re: PEI Question
Post by mikeamick » July 6th, 2019, 8:24 pm
Yep, nope .. lol .. I peeled both sides. The side that was sticky as hell, I put on the glass.
The other side ( the work surface side ) had a really thin plastic peal off.
I bought the PEI sheet and a piece of glass from Amazon, and I don't think it should have bubbled and I can
not get it off of the glass so both need replaced. But if I did ANYTHING wrong that wouldn't be right.
But all I did was properly apply the sheet and heat it up per instructions and it melted the stuff.
Re: PEI Question
Post by LePaul » July 11th, 2019, 12:00 am
Very weird, where did you get it?
