Print Speed - How to cacluate It!
Discussion of RepRap style printers!
Post by Roberts_Clif » August 21st, 2018, 10:44 am
Marlin 1.1.5
#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 1600, 94.4962144 }
#define DEFAULT_MAX_FEEDRATE { 200, 200, 5, 25 }
#define DEFAULT_MAX_ACCELERATION { 3000, 3000, 100, 3000 }
#define DEFAULT_ACCELERATION 3000 // X, Y, Z and E acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration for retracts
#define DEFAULT_TRAVEL_ACCELERATION 3000 // X, Y, Z acceleration for travel (non printing) moves
#define DEFAULT_XJERK 5.0
#define DEFAULT_YJERK 5.0
#define DEFAULT_ZJERK 0.4
#define DEFAULT_EJERK 5.0
Cura Startup G-Code
G21 ;metric values
G90 ;absolute positioning
;M106 S127 ;set Fan half speed
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
;Put printing message on LCD screen
M117 My Print...
G28 X0 Y0
G1 E4.0 ;prime extruder
G92 E0 ;reset extruder length
M420 S1 ; Bed Leveling On
M220 S32.000000
Sample Inside G-Code
G1 F2400 E12.58997
G1 Z0.355
G0 F9000 X116.217 Y143.936
;TYPE:FILL
G1 Z0.280
G1 F2400 E17.08997
G1 X116.298 Y144.017 E17.09531
G0 F9000 X115.981 Y144.020
;TYPE:WALL-INNER
G1 F2400 X116.404 Y143.381 E17.13099
Inside Cura At a Speed of 86 if you hover over the Print Speed is shows
"You are trying to print a more then 8.0mm^3 of filament per "
"second. This might cause filament skipping. (You are printing at "
"9.6mm^3 Per Second)"
Is this correct or is my settings causing my printer to print at a different rate.
Mind you that my prints come off at almost exactly Cura's estimated time.
I am thinking because the Slicer sends the F2400 the speed are not correct, but 80 percent of the set F3000.
So that would make my print speed of 86 actually 73.96 or
"8.3mm^3 Per Second"
Is my understanding close to correct, if not please direct me to how to calculate my actual print Speed.
Thank You
Re: Print Speed - How to cacluate It!
Post by Roberts_Clif » August 27th, 2018, 9:15 pm
Maybe I stated it incorrectly - How do I calculate my Print Speed in a way that can be understood.
Post by GrueMaster » August 27th, 2018, 10:38 pm
If you know math, check this out.
Post by Roberts_Clif » August 28th, 2018, 8:12 am
Thank you, The numbers seem higher than expected, did you calculate for you machine
Strange I search many times and could not find a Calculator for filament speed. Then saw your Web copied the "RepRap Max Printing Speed Calculator"
and many came up. O found this one that is easier to understand.
Print Speed Calculator
I when you hovering over the Print speed in Cura a number appear in a pop up box mine was (" 9.6mm^3 per sec / 3.99 mm/s ") and was told that this number Quote "how is that even useful ? lol",
Well every one says they print at XXX speed percent this number is useless without knowing how much filament is being printed per sec.
So when someone asks the Speed, we should use this Speed reference Print Speed Calculator this way we are all on the same calibration and can compare how our 3D Printer compares with others.
susanneadam
3D Printer(s): Ender 3
Post by susanneadam » March 5th, 2019, 5:58 am
Especially if you are new to 3D printing, then choosing the right speed for your print can be quite a challenge. After a bit of trial and error, you will be able to guess a setting that will generally work. There are many tools available online to calculate the right printing speed.
Return to “RepRap Printers”
