Page 2 of 3
Re: Nudee: One bridge too far?
Posted: March 11th, 2016, 8:53 am
by nallath
ivan.akapulko wrote:Whoa... Um scanner? As a part of printer or standalone solution?
Standalone solution. Think UMO, but instead of printing it scans. We got in a pretty late stage of the development, but then it was cancelled.
Posted: March 11th, 2016, 8:59 am
by ivan.akapulko
So sad... I look before at bq's cyclop, but it looks most like a toy, not a tool. Any chance to continue scaner's r&d in future?
Posted: March 11th, 2016, 9:05 am
by reibuehl
I have a BQ Ciclop at home but it currently sits in a corner as the initial results where not very good. The Ciclop seems to have issues with very dark scan objects - at least mine had. Once I have more time, I will give it another try with latest firmware and scanning software.
Posted: March 11th, 2016, 9:10 am
by Amedee
If you have 'a few' Raspberry Pi's, you can try
this...
Posted: March 11th, 2016, 9:22 am
by ivan.akapulko
100 is "a few"? Interesting, if use just 10 of it on a vertical stand, and rotate object at 360 degrees can it take similar result?
Posted: March 11th, 2016, 9:32 am
by Amedee
Yes, if the subject does not move
Here he can fire the 100 Pi's at the same time.
A friend of mine is offering the same service with a simple setup: a rotating stand and kinect scanner. It the subject don't move it is very effective.
On a smaller scale and only with objects I do it by taking pictures as well. I have an Arduino which rotate the stand and takes a picture every X degrees, then I move the camera and do another round. It gives very good results (that's how I scanned the bear)
Posted: March 11th, 2016, 9:39 am
by ivan.akapulko
What is a cost of kinect stand?
Posted: March 11th, 2016, 9:41 am
by ivan.akapulko
I remember, previously on a umforum couple of users told kinect is a not good solution. Something like 3dsystems hand scanner
Posted: March 11th, 2016, 9:53 am
by Amedee
Yes, you can find easily tutorial on how to scan with a Kinect. Price tag is I think around 100€, but you can find them for much less than that on the Bay.
Posted: March 11th, 2016, 9:58 am
I have a Microsoft Windows Kinect and I'm really not sure what to do with it.
I got it rather inexpensively using a student discount. My thought was I could place this inside of R2-D2 and use it for some basic level of navigation. The opening between the dome and utility arms looked promising since that area is open.
But that is a narrow opening. And to make things a bit more complicated, as things always are with R2, the droid is tilted back 17 degrees.
So the area the Kinect could "see" was quickly getting smaller and smaller.
I still have it, plus some additional ultra sonic sensors that could be hidden around the droid for actual navigation.
With a droid like this, you are struggling to be "screen accurate" and not have any gizmos showing.
Posted: March 14th, 2016, 4:25 am
by nallath
I'm working on the scanner on my own time now (together with some colleagues of mine). With a lot of luck it might ever see the day of light.
I don't think that Ultimaker will let me form a spin-off company for the scanner though. Might be able to convince them to throw all the research we made into public domain.
Posted: March 14th, 2016, 4:13 pm
by Anders Olsson
Harma from Ultimaker actually talked about the scanner project almost exactly a year ago on the 3DVerkstan "3D Print Meetup 2015" in Stockholm
http://3dverkstan.se/3dprint-meetup)
I suspected that it was cancelled since there were no news about it since then, but it would be really interesting to know more about what has been done
As I can remember, the prototype had the wooden look of an UMO and appeared to be roughly the size of a Filastruder
Posted: March 15th, 2016, 7:53 am
by Blizz
Off-Off-Topic here but that meetup might be a good excuse for me to go to Stockholm
Posted: March 15th, 2016, 8:44 am
by reibuehl
Will there be another one this year?
Posted: March 15th, 2016, 9:26 am
by Meduza
Not the same one, but since we just moved into a new much larger space with 3DVerkstan, wich includes our own 100m2 meetup space, we will surely be hosting some interesting 3d meetups in the future
