Hi,
instead of trying a useless test post, I thought I use my first post to suggest adding a proper SSL certificate to the forum to make it also available via https. I do not know what server is used to host the forum, but if you need help setting this up, I am willing to help.
Best regards,
Reiner
SSL for the Forum
- Site Admin
Re: SSL for the Forum
That might be a really good idea.
We're Linux hosted via GoDaddy. Feel free to PM me
- Site Admin
Upon reading up on it...it looks like a lot more work than I want to tackle right now!
It is actually not that much I would assume. The site IS already available via SSL, it just presents the wrong certificate. If you have a Linux vServer, then installing one e.g. via the Lets Encrypt shell script (https://github.com/lukas2511/letsencrypt.sh) shouldn't be a big issue.
I will sent you a PM.
Seems like I can't send PMs yet.
Fixed the PM issue, had to correct some code that wasn't removing Newly Registered users after registration.
