Issues with print job when retracting.
wridley
3D Printer(s): Hictop 3DP18
Post by wridley » September 3rd, 2017, 11:18 pm
Having issues with print quality after printer gets to areas where it needs to retract.
A couple months earlier with the same file and settings, this was the result.
I haven't used the printer for a couple months but nothing has changed. I have tried numerous times with not much difference. Same result using the same white filament. Printer is a Hictop 3DP-18
Suggestions welcome.
Thanks
Re: Issues with print job when retracting.
Post by reibuehl » September 4th, 2017, 4:48 am
Since you mention that the printer hasn't been used for a longer time: Has the filament been stored dry? Maybe you have moisture in your filament and that produces these extrusion issues. Gently drying the filament could help then.
Reiner.
wridley
Post by wridley » September 4th, 2017, 11:02 pm
They have been stored in sealed bags, but it is worth a try.
