Tips on Post Processing
Posted: March 10th, 2019, 3:01 am
by JackMcConick
After breaking off supports or sanding, I usually use a lighter to heat up the plastic to remove the white discoloration on my prints.
Searching around, I'm seeing others using
small butane torch or
heat gun to refine the print. Any thought?
Re: Tips on Post Processing
Posted: March 11th, 2019, 9:32 am
I'd be really careful with an open flame but heat guns are good at getting the hairs off a stringy print
Posted: March 12th, 2019, 12:02 am
by JackMcConick
Thanks a lot Le Paul for your input. Hopefully i will get better results with the heat gun.
Posted: March 12th, 2019, 10:31 am
It's a lot like soldering and shrink tubing. A heat gun shrinks it up nicely. An open flame scorches it and you're left with brown/black heat shrink
