Tips on Post Processing
JackMcConick
3D Printer(s): ARTEMIS 300 RTP™
Post by JackMcConick »
After breaking off supports or sanding, I usually use a lighter to heat up the plastic to remove the white discoloration on my prints.
Searching around, I'm seeing others using small butane torch or heat gun to refine the print. Any thought?
Last edited by JackMcConick on March 14th, 2019, 9:29 pm, edited 2 times in total.
Re: Tips on Post Processing
I'd be really careful with an open flame but heat guns are good at getting the hairs off a stringy print
JackMcConick
Thanks a lot Le Paul for your input. Hopefully i will get better results with the heat gun.
It's a lot like soldering and shrink tubing. A heat gun shrinks it up nicely. An open flame scorches it and you're left with brown/black heat shrink :)
