I have been working with Prusaslicer alpha versions recently and find it very powerful.
Like the project save function I can setup special characteristics that are to be preformed, upon loading the 3mf file all settings are restored.
So if I make a temp tower 190 C to 230C I can save this model give it to someone all setting are loaded with the model.
If fact all special parameters set in Prusaslicer all preloaded with the Project model.
Prusaslicer
Re: Prusaslicer
I am new to Slic3r looking for information on How to adjust all the settings in the slicer.
I have a Prusa i3 compatible 3D Printer a Hictop 3DP11/12 which has a 220 X 270 X 190 Build Area.
As the Prusa Slicer is compatible to Slic3r I will be using this Prusa Slicer 2.3.0 alpha 2,
Have four working pretty well at this time in the newest version of Prusa Slicer.
I am finding that the Ender profiles are working with little adjustments.
The top Dragon is starting to show more detail with a modified Ender 5 profile.
Though they take longer to print the same model than using Cura.
Would like to operate PrusaSlicer at the same speeds it appears to be a excellent slicer.
Decided to print a pre-sliced model G-Code from Prusa Printers.
It printed perfectly. Now I need to go through the Modifier meshes tutorial to see how I can do this myself.
Printed On MY Hictop 3D12
