Print start movement
m4RT1n
3D Printer(s): Tevo Tarantula & Black Widow
Post by m4RT1n » January 24th, 2018, 5:03 pm
hello ;-)
someone here can tell me if it is possible to change the way S3D move to the printstart point?.
After the homing/autoleveling the nozzle is 10mm from the bed and it moves first the Z-axis
to first layer high and then move XY-axis to the startpoint.
i would like to move XYZ together to go linear to the startpoint ( or first XY then Z )
I think its not that easy because i think its in the slicer programming but maybe it is possible
to change the gcode to get it working.
thanks for the help :)
Return to “Simplify 3D”
