Page 1 of 2
Hole gaps
Posted: April 15th, 2017, 8:23 am
Hmmm. Looked good in preview mode
Perimeters/shells set to 6 6 and 6 as advised by thenpart designer.
Re: Hole gaps
Posted: April 15th, 2017, 3:28 pm
by Izzy
Somewhere there is a %overlap so the infill goes further into the outline to help prevent this
Re: Hole gaps
Posted: April 15th, 2017, 4:46 pm
Ah yes. What do you usually use for this?
Re: Hole gaps
Posted: April 16th, 2017, 3:02 pm
by shurik
The default 15%?
Re: Hole gaps
Posted: April 16th, 2017, 3:53 pm
by Izzy
Depends on he geometry sometimes I'm up to 50% to ensure overlap.
Re: Hole gaps
Posted: April 16th, 2017, 4:19 pm
Really?
See with the bigger pieces I print, S3D has done well....if there are no holes. Then I run into this issue
If I use Cura, I run into the grinding over the surface...requiring some z-hop....which should really just be part of what Cura does! I'm trying this very print on Cura and from upstairs, I can hear it grind away on the surface. Very aggravating! One slicer won't do holes right, one will but drags across the surface!
Re: Hole gaps
Posted: April 16th, 2017, 4:46 pm
Here's what 0.40 nozzle and 30% Outline Overlap did
Re: Hole gaps
Posted: April 16th, 2017, 4:53 pm
How many print hours have the coupler?
Re: Hole gaps
Posted: April 16th, 2017, 4:55 pm
257
But here's the thing....only an issue on printing items with holes in S3D
Did the kitten print recently and it came out gorgeous!
I'm seeing what 50% does in the preview now
Re: Hole gaps
Posted: April 16th, 2017, 5:03 pm
Post the FFF, it might be that cura uses a smaller nozzle simulation, that allows thinner lines (les possibilities of gaps, but slower and also extrudes less mm/2 so there's less material per/second and that helps to push the filament. Maybe you just need to raise the temp 5-7C?
Re: Hole gaps
Posted: April 16th, 2017, 5:18 pm
I'm using the same as before, Frederick's...with the suggested changes you offered a bit ago (he has an extended so Z is 210, uncheck Coast at End, etc)
Re: Hole gaps
Posted: April 16th, 2017, 5:25 pm
So here's what 50% Outline overlap looks like
I am starting to wonder if I have too many perimeters (The designer has top, bottom outline set to 6...since it's a structural pieces, he advised it for more strength)
Re: Hole gaps
Posted: April 16th, 2017, 6:14 pm
Yeah....it's definitely the perimeters...if I take it down to 4 (from 6) I get this...
Re: Hole gaps
Posted: April 16th, 2017, 6:35 pm
You could, like I said, change the nozzle width extrusion from default 0.4 to 0.35, alower print time, much less chances of gaps
Re: Hole gaps
Posted: April 16th, 2017, 6:48 pm
I did that on the first time through, used 25% outline overlap and 0.35 nozzle (6 perimeter, 6 top, 6 bottom)
