Default Print Speed
Default Print Speed
On my UM2+ Profile I got from Frederik, I see 35%. Is that too slow? Just right?
Re: Default Print Speed
35% ? Screenshot pls
Neotko wrote:35% ? Screenshot pls
Ahh 35mm/s no %
Sure is slow. Adjust speed and temp ofc
What would you suggest?
How can I know? I don't use 2.85mm, nor a um2+ feeder.
You need to test test test test test, and then test a bit more. That's the path to self enlighment
okay
Return to “Simplify 3D”
